RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   MT2 engine trouble (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/5452323-mt2-engine-trouble.html)
adam1979 02-21-2007 12:23 PM
MT2 engine trouble
Hi all. What does it mean when there is fuel coming from between the cooling fins and the main engine block???
Adam
buggymangp 02-21-2007 12:34 PM
RE: MT2 engine trouble
hey adam
i had the same problem with my 18ss engine.
do you have the same engine.
i had fuel leaking out when the engine was running so i thought
it was the gasket between the head and block.
it turned out it was the glow plug gasket was egged shaped. it happened when i first got the truck and i think
it was my fault beacuse as soon as i got my truck i pulled the stock plug out and put some after run oil in it
and i might of bent the glow plug gasket.
adam1979 02-21-2007 01:08 PM
Different engine. When you say the glow plug gasket are we taking the copper washer??
Adam
buggymangp 02-21-2007 02:51 PM
hey adam
yep. the copper gasket. the only way i found the leak was to run the engine
at WOT while looking down at the glow plug. the fuel was pouring out big time at WOT.
