Turn a Mt2 into a truggy!!?
hi guys,
I want to let my Hpi mt2 look like a truggy. Im gonna make a big order at TowerHobbies, this is my setup: http://i3.photobucket.com/albums/y92/dool/Order.jpg Im planning to make dual disk mod, i made a custom upperdeck myself ;) What do i have to buy more too let it look/ peform like a truggy? And the stuff that i picked, is it good? or do you guys say you better can take this/that...? Thanks Liu |
RE: Turn a Mt2 into a truggy!!?
mabye some bigger wheels and tires, 17mm hexes, but then you'd have to change the gearing to accomadate them...If you are going w/ the .18 try to get an 1/8 buggy filter (looks and performance)...other than that it looks good
dude dont put 17mm truggy tires and rims on it
it will hurt proformance |
which is why he said you would have to change gearing up
Your missing brake pads, and a ofna hyper 7 wing and wing mounts work better imo...
get the conversion 23mm hex's from pro line and go with the 40 size rims and tires:D
i doubt bigger tires and wheels will work, they will probably rub the chassis and they wont allow your truck to handle very well, if you want to build your own custome truggy just get a hellfire ss kit
@rcdudegermy08 i want this spoiler cuz it is not too extremly wide, other 1/8 spoilers are like 21 cm wide, this is a 1/10 spoiler 17cc wide. And im gonna make custom wing mount ;). The filter i took is a high peformance filter(3 stage filter), many buggy's does have this right? What do you mean with a buggy filter anywhay :P, istnt it right that a filter just is a filter???? @MastaDizasta My dad got some braking pad fibre from his work, it will work also ;) Hmm bigger tires is not nessacery right.. the standard ones are wide enough for my car ;) and what murawskiallen said, it probb wil rub the chassis. How about the diff oil? I thought 5000 front and 5000 rear will be nice, i heard standard for truggy's / buggys the visicosity is 5000 front, and 2000 rear. Should i do this too? |
ORIGINAL: liu How about the diff oil? I thought 5000 front and 5000 rear will be nice, i heard standard for truggy's / buggys the visicosity is 5000 front, and 2000 rear. Should i do this too? :D. |
and u said hpi dish wheels were to expensive. Remember to get some heavy-duty diffs u dont need a steelspur gear just mesh it right and u wont have a problem. Before i striped spurs like crazy i adjusted the engine and now ive been running the same spurgear for about 6 months. POST PICS of ur upperdeck. IMO remember if the peeps dont post pics most of the time they are lying.
You might try a wing mount from a lightning 10 buggy....good luck on finding the part # though.Maybe the center diff from the lighning 10 buggy too!
I got a mt2 18ss version so de diffs are sealed ;)
@rapsucks_07I will take a picture but the car isnt assembled. I think i will post it tonight ;) . There is no other dish that will 100% fit, i took this one(and my budget went like 20 euro's higher thats like 25~30 dollar). So.. :) On the TH site i coudlt find the lightning 10 wing mount.... and heavy duty stuff is allready in a 18ss version. So i dont have to buy any other Heavy Duty parts. ;) Liu |
are they sealed?. I never knew that lol ;)
@djheptic jup you can see it here http://www.hpiracing.com/graphics/instr/10441/10441.pdf an tthen scroll down to page 11, then youll see that you have to put in 2 rubber rings.
Here are the pics of the custom upperdeck:);) it is not 100% this becuz im not ready ;) still have to make the edgdes roudner a bit an stuff like that The upperdeck http://i3.photobucket.com/albums/y92/dool/DSC02417.jpg lol.. and this is my car at the moment ;) :( find the parts!! :D http://i3.photobucket.com/albums/y92/dool/DSC02423.jpg Any last adjustments on the order that i will do?? cuzz im planning to order it TOMORROW (becouze of the discount) what do you guys think? gearing 16/49 or 16/48 ???? |
oops im sorry i douted u. the uperdeck looks nice whats the tickeness are u using. i was at the hardware store the other day and saw a small sheet of diomong plate it looks nice. all i can say now is keep up the good work. have u looked at the gpm center spurgear holder that would help u get the look of a truggy
Ty :D i used 2.5 mm thick alu plate
I know gmp has alluminium stuff, im first gonna buy this crap ;) then im gonna look an buy some GMP schocktowers, c cups and more ;). But first i have too earn some damn money! :D |
looks great!! I'd say 48 gearing, but I like torque, and lap times are made in the corners
same here, my lhs has a pretty small track so i dont have much use for top speed, i run a 52t spur and a 13t vented cb
ORIGINAL: rcdudegermy08 looks great!! I'd say 48 gearing, but I like torque, and lap times are made in the corners |
i agree on the .18 cv-rx
what an awesome engine i have it in my hpi mt1 and wow it rips i would say a gearing that gives more top speed it has waaayyyy too much torque and the top end is not great |
I orderd it :)
i bought 16/49 gearing, and NO diff oil ;) cuz im not 100% sure of the diffs are rlly sealed, lhs said not... so now its just waiting ;) |
Liu, I went with bigger tires on my MT2 and it looks pretty mean that way... not much bigger, I can check and let you know the exact ones that I went with...
I think they were proline dirt hawgs, bashers or dirt works... at any rate, they are a bit bigger than stock but not monster truck/truggy size.. the OS .18 CVR is a fantastic choice, between this and the tire change my truck is ballistic! |
thestratcat, do you got a picture of that ;)?
Today i assembled my upperdeck on my chassis: Look :):) http://i3.photobucket.com/albums/y92/dool/DSC02435.jpg from the side http://i3.photobucket.com/albums/y92/dool/DSC02437.jpg And a question [&:] Can i pull a wheely with the CV-RX with 16/49?? |
i doubt it very much maybe if u took the front drive shaft out u might just pull them off a little:D
lawl:D:)
