rustler
i am trying to figure out what engine i should get for my rustler, suggestions would be helpful
RE: rustler
thanx for the help:)
RE: rustler
huh???^^^
well i would go for the o.s. .18 cv-rx its got plenty of power and its only 110 on tower hobbies this one http://www2.towerhobbies.com/cgi-bin...&I=LXGGP7&P=ML but i think you need a short shaft so heres this one also http://www2.towerhobbies.com/cgi-bin...I=LXGGP7&P=ML\ its a direct dropin where as the 2.5 or 3.3 need a new header and throttle linkage this one just drops right in |
RE: rustler
I'd say 3.3. I know one that has it in his rustler and that thing hauls butt!!!:D:D
RE: rustler
I've got a 3.3 in my rustler. Over powered but alot of fun.
RE: rustler
On my old Rustler I had an OS .15 CV-X It was a great motor for bashing, started on the first couple pulls every time and held a tune very easily.
I had to do some cutting to get everything to mount up smoothly, however, I do have pictures of the install and all the things I cut to make the motor fit. -bryan |
RE: rustler
i dont think that i want traxxas, i was thinking .18 tz
RE: rustler
the os .18tz is a good choice. My friend has one it his tmaxx and loves it.
RE: rustler
Bashing or racen? Bashing, the .18 will work, but racen youll need a .12, then get the .12tz or the rb v 12.
RE: rustler
well i just mess around. i made the truck onroad because i just have street slicks. i want to have a lot of power and speed and i heard TZ was the way to go. what else would i need to run it with the TZ?
RE: rustler
is it a rustler , or a rustler 2.5. if its a rustler 2.5 all you need is the motor, and a new rear exhaust header.get the pilot shaft version. unless you have a starterbox, you will need the traxxas clutch nut 4144 http://www2.towerhobbies.com/cgi-bin...?&I=LXJF69&P=M . try getting the slide carb if its a 2.5 or a rotary if its a pro .15. goodluck.
RE: rustler
no i had a 2.5 but it died. so i will just need the header. which one will i need? also the clutch assembly is the same? anything i should beef up? thanx
RE: rustler
If you want speed better go with a 3.3 it will out run a TZ18 |
RE: rustler
naa, like i said i want to steer away from traxxas. i want to try something new:D that should be pleny fast and its inexpensive
| All times are GMT -8. The time now is 01:58 PM. |
