RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   Foam Inserts? (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/6164760-foam-inserts.html)
edge101 07-27-2007 06:32 PM
Foam Inserts?
I just got some pro-line dirt paws for my firestorm, but they didn't come with foam inserts so do I need to buy some or what? please help!
Snaut Rocket 07-27-2007 07:15 PM
RE: Foam Inserts?
well ya you do. there wont be no fit and your tires will be riding on the rim.
nothinbetr2do 07-27-2007 07:19 PM
RE: Foam Inserts?
yes, you gotta have foams. i just got some pro-line moabs, and they came with foams. you should check in to it
46u 07-27-2007 08:34 PM
RE: Foam Inserts?
My HPI Nitro Rush new out of the box did not come with tire foams.[X(] But they changed that and yes I recommend running them.
rclynx 07-28-2007 02:38 AM
RE: Foam Inserts?
Really depends on what kind of traction you want to get, and if you do a lot of jumping the inserts hinder the cushion of the tire................thats why there is usually a pin hole in most rims to let the air out and cushion the landing[:@]
toxic 2U 07-28-2007 10:48 PM
RE: Foam Inserts?
ORIGINAL: rclynx
Dude [>:] Get your facts straight before you post. Foams absorb shock from jumps and bumps and keep the tire from squishing down to the rim and also to build up the side wall of the tire so when in a turn the tire dose not want to lean on and roll on the wall of the tire. they also help with handling cuz they help stop body roll
nothinbetr2do 07-28-2007 10:51 PM
RE: Foam Inserts?
thank you, someone with some sense, we all need foams, even in my little bikes they have them
rclynx 07-29-2007 09:25 AM
RE: Foam Inserts?
I'm not your dude dud and you can get your facts right, your not even worth the argument[>:]
Dude Get your facts straight before you post. Foams absorb shock from jumps and bumps and keep the tire from squishing down to the rim and also to build up the side wall of the tire so when in a turn the tire dose not want to lean on and roll on the wall of the tire. they also help with handling cuz they help stop body roll
if you had a brain you would be dangerous[:-]
46u 07-29-2007 10:11 AM
RE: Foam Inserts?
I pretty much agree! And if you did not have the holes the vehicle would bounce too much and make handling worse. All so the holes are to let any water and dirt get out. I do not have holes in the wheels of most of mine but in the tires as this way centrifugal force slings the dirt and water out. Dirt really puts a hurting on the foams. Some put holes in both the wheel and tire.
nothinbetr2do 07-29-2007 10:16 AM
RE: Foam Inserts?
i wouldn't put holes in the tires, for fear of ripping the rubber while running
rclynx 07-29-2007 10:26 AM
RE: Foam Inserts?
so tell me what this guys quote has to do with holes in the rims...................you guys frost me[&:] foam me up Scotty.............many times in racing you run tires without foam so that your traction is much better because with the hard foam on the inside of a tire you don't get the right tire distortion for the best traction in corners or the tire height for speed in the straigh aways but don't ask me I do this for a living[:'(]
remember noe this isn't 15 lb MT this is a ST thread[&:]
46u 07-29-2007 11:05 AM
RE: Foam Inserts?
This is why they make foam is different hardness!:eek: I do not know about stadium trucks as I only race buggies but I have never seen any one race with out some sort of foam insert. [8D]
46u 07-29-2007 11:07 AM
RE: Foam Inserts?
You race for a living? If so who are your sponsors?
toxic 2U 07-29-2007 07:59 PM
RE: Foam Inserts?
This guy is just a little know it all b***h that just won't admit when he's wrong and he is going to spew forth crap to us all . Oh well lets just let him show us all what fools we all are . right? :D
Valve 07-29-2007 09:11 PM
RE: Foam Inserts?
You can't really run these things without foams. This guy talks like he knows everything but I haven't seen him make a logical suggestion yet.
toxic 2U 07-29-2007 09:57 PM
RE: Foam Inserts?
ORIGINAL: Valve
Yeah , looking back on some of his posts he seems to get snippy and snotty when someone dose not see things as he dose. but any-hoo who cares. take a look at his profile , 13 years building but only 3 operating ??? Humm ?? the air plane one looks kinda weird too :D
