RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   ?Revving? Rusty (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/6351921-revving-rusty.html)
Xtfreak 09-10-2007 07:43 PM
?Revving? Rusty
hi
there is a problem with my Nitro rustler when I push the Accel it just revs up it does'nt even move but when i take the 2 rear wheels off the ground and push the gas the wheels spin... but not fast. I took the Engine out (its a TRX2.5R) and checked the clutch and everything was fine. could someone help me please
thanks
XTfreak.
The_Shark 09-10-2007 08:34 PM
RE: ?Revving? Rusty
did you check the slipper clutch? also did you check to see if the axl hubs to the wheel is stripped? this happend to me and i thaught that i ruined my dif, it turns out its just the axles slipping.
worst comes to worst, check the diff, on some there is a limited slip that can get loose, and if that tight and you checked eveything the diff is probly screwed.
jatoracing33 09-10-2007 08:37 PM
RE: ?Revving? Rusty
your clutch shoes fine including the spring?
motorhead91 09-11-2007 02:12 PM
RE: ?Revving? Rusty
it sounds like the axle hubs are stripped, and hopefully thats what it is
AdioKIP 09-11-2007 07:37 PM
RE: ?Revving? Rusty
I had the same symptoms. It could be your differential output yokes. The stock plastic white yokes strip easily depending on if you have the older ones with two grub screws, or the newer setup with the one screw that goes all the way thru. Either way this may be your problem, check it and if it is I would upgrade to the steel output yokes.
Xtfreak 09-12-2007 05:13 AM
RE: ?Revving? Rusty
yes those are fine. are the yokes those white things connect to the driveshaft?
Xtfreak 09-13-2007 06:01 PM
RE: ?Revving? Rusty
So what part do i need to get?
The_Shark 09-13-2007 06:34 PM
RE: ?Revving? Rusty
first you need to pin point the problem. look at the wheel hubs first.
The_Shark 09-14-2007 09:36 PM
RE: ?Revving? Rusty
[sm=confused.gif]any luck
michaelb510 09-15-2007 05:30 PM
RE: ?Revving? Rusty
my rustler did the same thing and it was the idler gear inside the transmission. half of the teeth were stripped off of the gear.
Xtfreak 09-15-2007 07:06 PM
RE: ?Revving? Rusty
thats what i think the problem is but how do i check if it is the gears or the yokes???
The_Shark 09-15-2007 07:57 PM
RE: ?Revving? Rusty
look at them, you will eaisily notice a stripped peice.
Xtfreak 09-15-2007 09:24 PM
RE: ?Revving? Rusty
are you thinking of the spur or pinion gear?
Xtfreak 09-16-2007 07:18 AM
RE: ?Revving? Rusty
Cause I think its the planetery gears
Xtfreak 09-16-2007 10:24 AM
RE: ?Revving? Rusty
so what do I do then?
The_Shark 09-16-2007 10:51 AM
RE: ?Revving? Rusty
look in the tranny![:@]
i think your out drives are plastic too, check them, then check the wheel hubs.
jatoracing33 09-16-2007 12:07 PM
RE: ?Revving? Rusty
when you hit the gas, does the spur spin or not? if so then its your drivetrain if not then its your clutch shoes or something in that area...maybe the flywheel pins broke off for some odd reason
Xtfreak 09-17-2007 04:43 PM
RE: ?Revving? Rusty
1 Attachment(s)
Ahhh I found the problem [img][/img] that thing that in my hand is supposed to go in the hole of the spur gear[:@]. ok now that I found the problem what is the right setting for the slipper clutch?
P.S I might have uploaded to pictures or none at all. I still dont really know how to upload pics:D
Xtfreak 09-17-2007 04:44 PM
RE: ?Revving? Rusty
Oh and thanks for all your help guys:)
jatoracing33 09-17-2007 04:54 PM
RE: ?Revving? Rusty
pics dont show up for me
Xtfreak 09-17-2007 05:20 PM
RE: ?Revving? Rusty
Try clicking on them
jatoracing33 09-17-2007 05:27 PM
RE: ?Revving? Rusty
duh:eek: yea it might help if you have that on
Xtfreak 09-17-2007 05:30 PM
RE: ?Revving? Rusty
Its supposed to be stuck in the spur gear but it fell out:D
Xtfreak 09-18-2007 07:50 PM
RE: ?Revving? Rusty
ok now what is the right setting for the slipper clutch?
The_Shark 09-18-2007 09:34 PM
RE: ?Revving? Rusty
it should slip for 2seconds at full throttle. altough you can get away with one second. dont over tighten because you can blow out the spur or tranny.
