Ready to explode?
I've been experiencing some problems with my xtm .18. Every time I run it, oil sprays out of the space between the pipe and engine.
What's wrong?[:o] |
RE: Ready to explode?
try replacing the gasket, or just try tightening the manifold screws.
check for a leak, whether it be bad gasket or (somehow) a crack crankcase
Thats one thing I've been wondering about. I'm used to aircraft engines so my idea of gaskets are white cardboard looking things.
Now, on a car is the gasket that rubber thing on the back of the engine? |
the gasket is the pice that goes inbetween the manifold and the engine, its like a cardboard material.
heres what they look like [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDTA7&P=ML]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDTA7&P=ML[/link]
hmmm, I may be wrong, but when I pull up info on an xtm .18 I get this:
http://graphics.hobbypeople.net/gallery/146002.jpg If that is what he has, he needs this: http://graphics.hobbypeople.net/gallery/148484.jpg |
depending on the engine then its either a rubber ring or what slipknot showed you
ohh, i didnt know the xtm had an exhaust port like that.
I have that thing, but mine is red.
try replacing the gasket, or just try tightening the manifold screws. |
heres what you need [link=http://www.hobbypeople.net/gallery/148484.asp]http://www.hobbypeople.net/gallery/148484.asp[/link]
| All times are GMT -8. The time now is 11:40 PM. |
