Need Advice
I've got an Ofna Mutilator/32 and the thing accelerates so hard that the front end lifts and looses traction. No kidding the tires grow to about double diamneter, on the front, the engine leans out too. I've got 60 wt oil in the shocks and hard springs on all 4 corners, preloaded quite a bit on the rear so it does'nt squat so much. Any advice on tunning the diffs or anything else that might work would be greatly appreciated. I even thought about adding weight to the front end, but I dont think that will be a good idea.
Thanks in advance. |
RE: Need Advice
lay off the throttle till it gets moving?
RE: Need Advice
Yeah, I have to watch the throttle. But there are times when I need to hammer it and accelerate at full throttle, and right now I cant cause it's all over the place. That's why I ask about tunning diffs. Is'nt there a way to transfer less power to the front so it wont do that?
RE: Need Advice
change the diff oils, i have the mutilator too, great truck but need some fine tunig. I run 7 in the front, 10 in the center and 3 or 5 in the rear diffs, this should make the front grab more and give less spin, the rear is grabbing too much and making the front lift, this setup will make your front pull more, also the mutilator is a truggy, its not really a stadium truck.
| All times are GMT -8. The time now is 06:46 AM. |
