RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   Hellfire won't start (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/6871583-hellfire-wont-start.html)
littleredrooster679 01-07-2008 09:42 PM
Guys..
I just bought a HPI Hellfire, filled it with gas, charged the battery... and can't get it to start. It DID start for about 5 seconds, then cut out. I thought I flooded it, so pulled the plug and pumped the fuel out (twice), even changed the glow plug but it still won't start.
Any suggestions?
Thanks-Will
NitroNate 01-07-2008 09:46 PM
RE: Hellfire won't start
Try recharging your glow plug ignitor,or try adjusting your throttle trim.If it is cold outside then preheat it.
littleredrooster679 01-07-2008 09:47 PM
It's about 35 out... preheat what? Thanks
nothinbetr2do 01-07-2008 09:49 PM
here, this will help you out alot http://www.rcuniverse.com/forum/m_55...tm.htm#5517128
NitroNate 01-07-2008 09:59 PM
ORIGINAL: biker_grunt
Sorry.:eek:Preheat the engine with a hair dryer or somthing,then try starting it up.
littleredrooster679 01-07-2008 10:14 PM
Thanks.
I tried most everything, preheating it with a heater, letting out the xtra fuel if it floods, etc. Seems like alot of fuel winds up in the resonator (?) I tried the throttle trim in different positions also and it still won't fire.
Glow plug lighter has a fresh battery too, so I know it's working.
Any other ideas?
littleredrooster679 01-07-2008 10:49 PM
Man, this sucks! Am I wrong to believe that this thing was setup correctly at the factory (throttle trim, lean needle, etc)? I'm thinking that I should try to lean it out a little first?
I took a glow plug and put the lighter on it (in my hand) to test it and it starts glowing red alright, so I'm pretty sure that's good to go.
e10drifter 01-08-2008 12:19 AM
is this your first nitro car?
what you want to do is take the glow plug you, get all the fuel out the motor, try and get all the liquid out the muffler by tipping it. then, put the glow plug back in, and purge the fuel by putting your finger on the pipe and puling the string. do it like 5 times, then put in glow IGNITOR, and try to start, if not, then keep trying until it works. if there's alot of resistance, you either have too much fuel in it or not enough... sometimes the motor is flooded real bad so you gotta try and pour the excess fuel out the exhaust and just keep pulling the string. it took me an hour to start my car one time because it was super flooded.
muddinrc4life 01-08-2008 07:38 PM
probably to rich turn it back to base settings.
littleredrooster679 01-08-2008 10:19 PM
I got it started! Turns out my Glow plug lighter's battery wasn't charged enough (I guess)...
Now I'm 2.5 tanks through break-in and it keeps wanting to cut out, running sluggish too. What's up now?> I pulled the plug and it looks decent still. Do I need to turn up the idle on the carb at this point or what>?
46u 01-08-2008 10:27 PM
Lean it out a little.
littleredrooster679 01-11-2008 05:04 PM
Alrihgt.. I tried leaning it and it started again, and throttles up, but cuts out when I put it on the ground and accelerate. Any suggestions??
SaVaGe MaN SS 01-11-2008 06:30 PM
preheat the motor so the head at least gets warm to the touch, leave the glow ignitor on the plug for like 30 sec to get the combustion chamber heated up and if that doesnt work you have a bad g-plug or a pinched line.
littleredrooster679 01-11-2008 11:02 PM
I leaned it out (more) and it's starting to run pretty good now! One thing it's doing now though is the steering seems to have went out. It just stopped working, although the throttle still works. Any idea what that is? I charged the battery for awhile.
