Help carb problems with 2.5 rustler
ok well i have a rustler and i have only ran one gallon through it and the engine is well was tuned then it started acting funky. So i called traxxas and they said to richen my LSN so i did still a no go. So when i go WOT it just barely accelerates,and bogs, but when i just barely pull the trigger its as if it want to fly but doesnt scream like it did two tanks ago. Also it Screams when first run it for the first 5-10 minutes but i followed break in and everything. Also it runs hot no matter what.
RE: Help carb problems with 2.5 rustler
Sounds like you might have an air leak somewhere causing overheating.Try turning everything back to factory setting,but if it still overheats then its most likely an air leak.
Bogging at take off can only mean its either to lean or to rich,or mabye its time to clean the engine out. |
clean after one gallon?? well if its necasarry i will. but could my carb leak air??? also its set at factory.
| All times are GMT -8. The time now is 12:38 AM. |
