RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   RC10GT problem (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/7090294-rc10gt-problem.html)
wisewendell 02-17-2008 02:25 PM
RC10GT problem
My little brother has an RC10gt, and the problem is, We turn on the receiever, its fine, we turn on the remote, and the wheels and throttle starts jittering, we heard it might be batteries so we put new batteries in it, and it still does it...We ordered a new set of crystals for it, we heard that might be it. But anyways,
Any info would be greatly appreciated.
Thanks much!
~Wendell~
bneterasedmynam 02-17-2008 02:28 PM
RE: RC10GT problem
was it the rtr version? if so you might as well scrap the radio equipment because the rtr radio is complete junk.
wisewendell 02-17-2008 03:06 PM
RE: RC10GT problem
Not sure, we bought it used. it has futaba radio and receiver.Not sure if they're the original or not.
ORIGINAL: bneterasedmynam
NitroNate 02-17-2008 04:02 PM
RE: RC10GT problem
The new crystals should do the trick.If not,you might want to check if the same channel is being used by a nieghbor.
wolfgang123 02-17-2008 04:39 PM
RE: RC10GT problem
the same thing happens to me i have the rtr gt2 and once you standup and start driving its not a problem at all
wisewendell 02-17-2008 05:39 PM
RE: RC10GT problem
ORIGINAL: NitroNate
In the town we live in I doubt that is the problem...We are the only people in town with an RC truck so...Plus it just..happened, it was fine, we shut it off, then it was wacky...
We also tried maybe it was where we were at but we took it to the other side of town and stood up, sat down...its no good whatever we do:D .
Thanks much!
~Wendell~
savagexx1 02-17-2008 06:11 PM
RE: RC10GT problem
make sure its not a pinched wire, that happened to me once
avg_joe 02-17-2008 06:45 PM
RE: RC10GT problem
Check the routing of all the wires. Make sure that no wires are resting on the chassis, and that power wires don't cross, or lay on the antenna wire. Check to make sure all the plugs are in good shape, and plugged in solidly. And check all the wires for cracks/worn spots.
wisewendell 02-17-2008 07:15 PM
RE: RC10GT problem
ORIGINAL: avg_joe
There is a spot in the wire where the flywheel rubbed against it, theres no exposed wire though so I dont know if that could be the problem or not...and it just started doing it, I mean it was running fine, then we shut it off, and when we started it back up it was driving itself more or less..So...
Thanks much!
~Wendell~
avg_joe 02-17-2008 08:17 PM
RE: RC10GT problem
It could be enough of a weak spot in the insulation to cause interference. Wrap it in elec. tape or heat shrink and see if that helps.
wisewendell 02-17-2008 10:01 PM
RE: RC10GT problem
ORIGINAL: avg_joe
okie dokie, we'll try that:D
Thanks much!
~Wendell~
wisewendell 02-17-2008 10:35 PM
RE: RC10GT problem
The electrical tape didnt do anything, so we hoping the crystals will do the trick:D
Mr.Positive 02-18-2008 09:31 PM
RE: RC10GT problem
did u try insulating the receiver because if that touches the metal body or any other metal object then it makes jitters.
wisewendell 02-19-2008 09:56 AM
RE: RC10GT problem
ORIGINAL: Mr.Positive
well the receiver is inside of a rubber bubble inside of a plastic box so I dont see how that could be a problem..Ill check it out though to make sure its not touching metal anywhere:D
Thanks much!
~Wendell~
