RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   help with evader diff break In (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/7333677-help-evader-diff-break.html)
JerB 04-04-2008 05:14 PM
Hey there guys
I am having a problem, I need to adjust the ball differential and it says in the manual that I need to disconnect the rear camber link ( using pliers ) at the right rear tire. I am trying to get it off but am afraid of breaking it. Is there a easier way to get it off or do I just pull hard with pliers I dont want to mangle the plastic
I hope you guys can help me with this[&:]
Jeremy
rclynx 04-04-2008 05:20 PM
RE: help with evader diff break In
If you pry it close to the edge where it disconnects you shouldn't have a problem.........................that plastic is some tough stuff................try some needle nose [&o]
JerB 04-04-2008 05:27 PM
does it take a little force to pop it off the ball?
rclynx 04-04-2008 05:31 PM
sometimes it takes a lot of force [&o]
JerB 04-04-2008 05:34 PM
Im more of concerned with mangling the plastic with the teeth of the need nosed pliers[:@]
scottywilkes 04-04-2008 05:34 PM
i find the best way of doin it is not to pull on it, but to twist the ball end off.
AKA get some pliars onto it and twist the pliars downwards so it pops of the ball end, works a charm everytime
rclynx 04-04-2008 05:37 PM
grip the metal part with the plyers and pry the plastic off [:-]
JerB 04-04-2008 07:42 PM
Im still having trouble getting this darn turnbuckle from the ball cup[&:]
Jeremy
yoster 04-04-2008 10:54 PM
Again, grab the plastic ball cup by the metal joint and TWIST (not pull or pry). That's it, nothing more to say. You just need to do it. The worse that will happen is you break a .30 part.
bte214 04-05-2008 01:12 AM
+1 on twisting it off.
JerB 04-05-2008 04:28 AM
1 Attachment(s)
twist here [8D]
scottywilkes 04-06-2008 06:33 AM
what? No thats the turnbuckle, your trying to get the ball end of so u can drop the arm down so the CVD will pop out of the drivecup and u can get to the adjuster screw
The plastic parts on the ends are what u want to pop off
JerB 04-06-2008 08:53 AM
hey look at that, I got it [&:] I was just afraid of damaging it. I am a model railroader so am used to having to be very careful with parts but I see RC nitro parts are a little tougher [8D]
thanks again guys
Jeremy
JerB 04-06-2008 09:14 AM
another question guys, are the little foam pieces that go over the ball joints necessary??
rclynx 04-06-2008 10:53 AM
Not really if you keep your truck clean its about the same...........I never have had any trouble [:-] but they are good for keeping dust and dirt out :eek:
FastestJato 04-06-2008 10:55 AM
I dont think so, cuz my jato doesnt have any, but your truck might need them.
FastestJato 04-06-2008 10:56 AM
brownstone101 04-08-2008 03:20 PM
if im not mistaken jatos use ball capture ends evaders use ball cups. the cups can egg out and dirt can sand the insides out but i dont have any of those foams left and its fine but just leave them till they rot off [8D]
