RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   Propane (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/7403478-propane.html)
C.rusak 04-21-2008 10:01 PM
Propane
Hey, Im tryin to design a way to make a rc run on propane. It would be a lot cheaper, and the, motor would last a lot longer. If any one has any ideas, or comments feel free to leave them.
j8to33 04-21-2008 11:51 PM
RE: Propane
Good luck! Are you going to build your own motor or are you going to get a os 21tm for example and make it run off propane?
rclynx 04-22-2008 04:47 AM
RE: Propane
You would have to design a whole new intake system for a 2 cycle................it would be fun if you could come up with a way to calibrate the mixture..............might be able to do it with a slide carb.........Good luck [:-]
C.rusak 04-22-2008 08:25 PM
RE: Propane
Yea Im gonna do a lot of reasearsh and find some info to get a motor going. It could work but its gonna be a lot of work.
misasi 04-22-2008 08:52 PM
RE: Propane
call me crazy but i doubt this will work for more than a few min. car fuel has oil in it to lubricate the parts. if you run straight propane you will cease the motor.
motorhead91 04-22-2008 08:55 PM
RE: Propane
you could mix 2 cycle oil with it...just like 2 cycle gas engines
ridgewalker 04-22-2008 09:26 PM
RE: Propane
Fork lifts run on propane.So do all the gas co.vans.
misasi 04-22-2008 11:34 PM
RE: Propane
ORIGINAL: ridgewalker
any gas engine can be converted BUT they have to have an oil tank. A nitro motor does not. propane is a gas not a liquid how could you mix oil with it?
jumpanddrop 04-22-2008 11:48 PM
RE: Propane
i agree. probably the only rc engine that you can make run off of propane would be a 4 stroke
calvino 04-23-2008 01:03 AM
RE: Propane
maybe if you had an oil spray that entered the engine right as it was sucking fuel in?? that may work, ya, on a 2 stroke engine, the revs are WAY to fast to work on propane, somethin like a 4 stroke would work much better[8D]
digifox 04-23-2008 07:34 AM
RE: Propane
you know that would be pretty cool but yea..you need oil and you cant get oil in a gas...lol
but yea i`m sure this would be doable, and thing of the + like indoor running and CHEAPER fuel...lol
only thing is, you have to have it pressurized and that can be a problem if you hit something, unless you had a CF tank made[X(]
and you would have to use a 4-stroke since it has valves you wont waste any of the Gas
cuz if it was a 2-stroke it would just get to BDC and let all the pressure out..lol
