RC10GT Carb insert???
Hey everybody, I am not here very often anymore but I am installing a servo into a friend of mine's RC10GT and I pulled off his airfilter just to make sure it was normal. I found a white plastic carb instert in the carb throat. It isn't like any of the carb venturis' or inserts I have seen before. It has a hole (a small one) but it is to on side of the insert. I hope I can just take it out because it moves around and I can't get a consistent carb linkage positioning because the circle moves around.
I will have some pictures up soon. Thanks. |
RE: RC10GT Carb insert???
yes.. lets see what your dealing with... is it easy to remove?
it comes stock with the ae .15 motor pull it out and u get alot more power
Thanks multi. Does anyone have any pictures of a RC10GT with a NiMH hump pack setup in it?
slide it in length wisewith 2 cells on top and three one the bottom and ty it like i said and it works fine
| All times are GMT -8. The time now is 01:54 PM. |
