compression on a new motor
ok my buddy just got a brand new motor and it has never been used and the compression isnt very strong one you put the flywheel on you can turn it prety easy... and yes the glow plug is in. You can feel the pinch up top in the cylinder because of the way it goes through. is it bad there aint much compression?
RE: compression on a new motor
I have the same question and i was thinking its ok, if it was already broken in.
ya this one isnt broken in its brand new not even ran
I have had some engines that started out looser than others , could be normal .
What engine is it ? Did you check the bolts on the cooling head and make sure they are tight ? |
its the trinity .12 draked touring edition...l i will do so.
