RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   Having trouble getting started, help please? (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/8398487-having-trouble-getting-started-help-please.html)
griffboy789 01-25-2009 09:18 AM
I have got a new hpi mt2 18ss+, i have checked the glow plug and returned the needle settings to the base positions
I think the problem is that th engine gets floode, i do not have an ehgine primer so i usually prime it by blowing through the pressure release tube.
Any suggetions that might get it up and running?
thanks
shane.corn 01-25-2009 12:21 PM
RE: Having trouble getting started, help please?
Try taking the exhaust off and starting it. I had one that came with a defective exhaust straight out of the box,. It did the same thing to me.
Chris_RC 01-25-2009 01:18 PM
lean the lsn a little bit. or idle needle. What you should do is Hold the exhaust nipple with your finger and pull the pull start a couple times till it JUSt reaches the carb. the second it reaches the carb, stop priming. Get a fully charged glow igniter and you should be good. if it still doesnt start heat the head with a hair dryer and try to get it as hot as you can.
griffboy789 01-28-2009 05:06 PM
thanks for the advice, i tried these and they worked, i ran the ngine in (two tanks at idle and one moving at low revs), brought it in to fix the brakin problem and now it wont stard up again, any suggestions?
