Problem with killer body LED kit?
Apologies if this is in the wrong plave, was unsure where to put it?
I got a 18 LED kit from killer body with a small control box but I can't get it working?
It comes with 6 LED for front spots, 4 LED for main head lights, 4 LED for tail lights, and 4 orange for indicaters
I plug the system in ( channel 3) and all I get is all the LED flashing and nothing else. Iv tried various combos and tried the kit in 2 different cars but still get the same? Instructions are also pretty rubbish, what am I doing wrong?
Most of those LED kits comes with Y harnesses to connect both the steering servo/LED box (ch 1) into the channel 1 port on the receiver. The other Y harness will connect the ESC/LED box (ch 2) into the channel 2 port on the receiver. The purpose of the LED controller box is to receive signals from input done by you and your transmitter. The LED controller then sends power/limits power to the appropriate LEDs when you brake; turn, and accelerate.
As far as the A,B, and C positions on the LED controller box...my best guess as to what they do...LEDs all on/LEDs controlled/LEDs all off.
I hope I got you pointed in the right direction
Good Luck.
Good Luck.
