RC Painting, Detailing & Bodies Discuss painting techniques, methods and materials. Also detailing and bodies
2 tone matalic paint
Old 10-03-2003, 02:14 AM
mad_taffy2k
mad_taffy2k's Avatar
Default 2 tone matalic paint
hi i want a 2 tone or more coulor matelic paint u know like on the tvr cars i want a purple going to green how do i mix this up i got an air brush so please can u advise me
Old 10-03-2003, 02:31 AM
Tigger N. Bennie
Tigger N. Bennie's Avatar
Default RE: 2 tone matalic paint
Faskolor makes its Fasglitter that you can mix with its Faskoat and use with a Fasecent color--the different colored glitters will create different effects depending on the colors used and the spray. The glitter is hard to shoot though because recommended air pressure is from 40-70lbs and will clog up your air brush very quickly or at least it did mine when I first tried it in my Iwata Eclipse BCS. As an alternative, I've met a few people who have sprinkled the Fasglitter on by hand.
Old 10-03-2003, 08:19 AM
R6stunter
You can also try spraying candy green and candy purple and back it with metal flake. the more metal flake you put behind the candy the more "bassboat" it willl look.also the thinner the candy is the lighter the color will be and more metalic looking. Hope this helps.
