can electric tape be used instead of masking tape??
CA
RE: can electric tape be used instead of masking tape??
I think that electrical tape would be too hard to cut for fine cuts.
It tends to shred rather then cut in my experiences.
i have tried it before and it doesnt work real well. electrical tape is elastic, so it tends to return to its orignal shape. this plays havoc when u are trying to mask of corners. plus - it doesnt stick very well, and tends to lift a bit, causing over spray. stick to what the pros use, painters masking tape.
koo, thanks for the responses, i bougt the painters masking tape already but i read on some rc site about this guy using elec tape and i was wondering if it works b/c iono the painteres tape that i bought doesnt really have a whole lot of stickyness to it.. guess i'll just have to try it and see... btw i bought 3m painters masking tape (its blue masking tape)
the blue kind is a lil light on the adheasive. i noticed that too. i like the tan better. but the blue will work, just make sure u really rub it down good with ur fingernail around the edges.
I've used it in a few places and it worked for me. If you read the 'How To Paint' website everyone talks about, I believe he mentions using electrical tape there and I believe he has success with it.
I prefer masking tape though and havent used electrical tape much, just for a bumper or two. I didnt have a problem with residue.
http://www.rctech.net/articles/paint...ntedmyst.shtml
He talks about the tape in the Masks section.
electrical tape is more a pain in the arse.
the blue tape you got is a medium tack. you might try the green or tan instead. the white is whay to light.
i use the blue for many things, but it is not heavier enough in tack for me for the use on lexan.
i was wondering, can i paint the wheel well? or will that effect the paint job when i am cutting out the wells and the body...? and how many ppl use the regular masking tape that can be bought from home depot, like i mean regular tan big fat roll for like a buck or two masking tape... and how affective is the green tape?
i use all regular tan stuff, in different thicknesses, i have some about 2 " and some as thin as 1/4 "
if you use the right paint and everything you wont have to worry about getting it on the wheel wells. on my first body i painted i used this blue tape it was awesome. It is painters choice stuff and leaves no resadue on the body and stays in place. I would use that tape it isan't real expensive andworks great.
