Can i added a few more coats to an already painted body?
MD
i have a body that only has 1 coat of yellow on it and its been that way for 3 months, can i added more paint to it? or will is look bad? i want to know cause i can almost see through it!
RE: Can i added a few more coats to an already painted body?
I don't see why not, especially if the outer plastic covering is still on the body. I would suggest using a blow dryer with cool air to blow any of the dust out of the inside of the body first before painting.
yeah you can add more paint. just use yellow or white. and make sure to wash the inside of the body with soap and water before painting. just scrub with your fingers and nothing abrasive or else you will scratch the other yellow and you will be able to see the scratches. good luck!
drew
drew
