Clearcoat?
Clearcoat?
Does anyone use clearcoat spray on top of the paint?
I was thinking of this sequence --> base 2 coats- then clear- then stickers- then clear. Anyone ever do that?
RE: Clearcoat?
If you painted the outside of the body, that might work ok. but since R/C bodys are painted from the inside, that would not work.
i have used clear before on the inside as a protectant, but i have not done that in a long time.
RE: Clearcoat?
ORIGINAL: speeddemon32
RE: Clearcoat?
ORIGINAL: HPIRS4-3SS
you paint inside, and the put decals/stickers on the outside of the body.......and the paint does show thru good
MD
RE: Clearcoat?
ORIGINAL: l7avis
Ok thanks, how about puttin clear over the stickers so they won't peel and to add gloss?
