Painting
CO
RE: Painting
Depends on what you want the yellow to look like when finished, if it is non metallic yellow use white and it will give you a bright vibrant color, metallic yellow use silver and it will bring out the metallic flake in the yellow more, and if you want your yellow be look a bit darker back in it black but not too heavy, just a good even coat.
