RC Painting, Detailing & Bodies Discuss painting techniques, methods and materials. Also detailing and bodies
Putting pictures on your body
Old 11-23-2004, 03:24 PM
Rick1805
Default Putting pictures on your body
Ok I am trying to find a how to attach custom pictures to the inside of your body before painting it
anyone with a link to this please post it my google search has turned up nothing as usual
Rick
Old 11-23-2004, 06:22 PM
bamaracer0
bamaracer0's Avatar
Default RE: Putting pictures on your body
XXXMain makes a picture glue where you can put the picture inside the body then paint over it.
It is found [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEGG8&P=7]here[/link]
Old 11-23-2004, 10:09 PM
Rick1805
Thank you I took a ride up to my LHS and asked them if they had that and they did and some cool paint so will be expermenting
Rick
Old 11-24-2004, 12:10 PM
Dalejr08
I did this over the summer with a BMW body, Its pretty easy, I bought a book abut special paint jobs for help. I just cut out the pictures and glued them to the body with some white school glue. It dries clear and is easy to wipe up the extra. All I had to do was wipe out the air bubbles. Heres my results (hope I helped you at least a llitle)
ID:	196236   Click image for larger version
Old 11-25-2004, 11:43 PM
Rick1805
Ok heres my first atmept at the pic's in the paint I did this one for the place my wife works
Ok and these are some other bodys I have done the one on the right is the one I "test" and race with the one on the far left is signed by the nascar driver so dont race that one at all
Old 12-06-2004, 02:35 PM
Snipcod
Do you have to use pics from mags and of that kind. Or can you print your own from your PC. And if so do you need a certain kind of paper, like a gloss or will reg paper work
Old 12-06-2004, 05:59 PM
Dale RC Painting
I have successfully used computer printed pictures on regular paper by applying a thin layer of Fascoat, on the exposed side to be painted over, with a Q-tip to prevent any paint bleeding through or shadowing the paper.
http://www.geocities.com/dalemotorsp...odiespage.html
Old 12-10-2004, 10:12 AM
DaytonaTurbo87
Okay so how exactly does this work? Do you glue the pic on the inside and then just mask over that area on the outside or what?
Old 12-10-2004, 10:58 AM
shell shocked
shell shocked's Avatar
paint the picture with the glue and stick it to the shell, it dries clear and is fairly flexible. you can then paint over it.
Old 12-11-2004, 07:57 PM
802's Avatar
Can you do this to apply the decals to the inside of the body insted of having them scrape off the out side?
Old 12-12-2004, 03:09 AM
shell shocked
It should work but it could react with the decal. The other problem is I dont know if the paint would dry properly on the adhesive on the back of the decals.
