RC Painting, Detailing & Bodies Discuss painting techniques, methods and materials. Also detailing and bodies
200mm &190mm ???
Old 12-12-2004, 08:49 PM
RS4 BuDDy
Default 200mm &190mm ???
Whats the differnce between 200mm and 190mm ? besides the fact that 190mm is off by 10mm. i have a hpi rs4 2 will a 190mm body fit it?? thanks
jason
Old 12-13-2004, 01:37 AM
69 GTO
Default RE: 200mm &190mm ???
Main difference is the wheel well opening. The difference between the 190 and 200mm will be mainly the measurment from the center of one wheel well to the other since they are designed for different wheel bases. Its not a whole lot of difference (less than 1/2") but if your talking touring car then thats enough to screw up the placement of your wheels in the opening to where you would have to do some trimming and it might look a bit "off" then.
