RC Painting, Detailing & Bodies Discuss painting techniques, methods and materials. Also detailing and bodies
Testors Decal System
Old 12-22-2004, 04:11 PM
Grndzer
Grndzer's Avatar
Default Testors Decal System
http://www2.towerhobbies.com/cgi-bin...&I=LXESK4&P=ML
any one tried this? I want to put the decals on the inside, I know these are made for the out side but would it matter?
Old 12-23-2004, 03:04 PM
jojowasher
jojowasher's Avatar
Default RE: Testors Decal System
it would probably work, but painting the body might make the ink on the decal run.
You would also have to print the image mirror so it would so up correctly on the body.
Jojo
Old 12-23-2004, 05:52 PM
Kregger
I bought the system but used the decal sheets from mirco mark instead. It works OK. The spray that comes with the kit should seal the stop the printer ink from bleeding. Just be careful I found that to much spray melts the decals. The only problem I had was that I applied it to the outside of the body and lexan seems to slick for the decal to really get a good grip (mine is starting to peel up on the hood.). You probably won't have that problem if you applying the decal from the inside and then painting on top of it.
