Scissors and reamers
OH
I've been looking at scissors and reamers since I need to replace a few bodies. Problem is they vary in price so much.
Is there a difference between the ones that cost $5-$10 each compared to the ones that go for as much as $20?
Anything in particular that I should consider?
Mark
Mark
CA
RE: Scissors and reamers
hm...scissors and reamers?...I don't know, but I can give you one suggestion. Reamers are not worth their price, so you should find another way to poke holes in the body. I use a lighter and a nail and heat the nail so hot that it just melts through the plastic.
Most hobby shops carry the dynamite brand of scissors for about $12 they are a good pair, mine has stayed sharp for 5 years so far. I have to disagree with reamers not being worth the price, they will give you a nice crisp clean hole that is perfectly round and however big you want the hole to be. Heating a nail would still leave you with mealted lexan that would have to be trimmed up to have a good looking hole IMO.
I usually put a small hole through where the hole needs to be with the x-acto then run a small (about 3/16th) drill through it then use the reamer to open it up. The small hole from the x-acto help to keep the bit from walking.
CA
I'm a mechanic so I have 'uni-bits' in the toolbox. (kinda expensive, although I've seen 'knock-offs' cheaper) I start it with the x-acto, use the bit with a home made handle, hand drill it to size, and finish with a light sanding. Perfect every time.
IA
I love my reamer and lexan sisscors... Will not trim a body without them! They make the job extremely easy and no need to worring about messing up the body!
CA
These dont look bad! http://www2.towerhobbies.com/cgi-bin...?&I=LXJGU5&P=7 i would recomend these just cause of price.
later
later
IL
I bought the dubro pack at my hobbytown and they work great. The reamer is ok and the scissors are awesome. I would go with the pack its like $10.
