XXXMain Picture Glue
Had To do An ICEAGE Theme, As You Can See It Worked Out, Used The Picture Glue From xxxmain.com Cut-out Pictures Glued The face of The Picture And Stuck Upon The Inside Of The Body..
http://www.rc10b4.com/forum/showthread.php?t=7422
TX
Looks real good. Some close-ups would be nice. I got some of that XXXMain Picture Glue this weekend and am going to attempt putting pictures in a body. Just need to figure out what theme????
IL
just whenever you do use it, make sure to back the image with white or silver.i used a red paint and i forgot to use a backer on the images and it turned out that the red bled through quite a bit. so be careful
