how do i prevent paint chiping????
hey i was just wondering how to stop the paint from coming off the inside of my body. if you have any secrets on how to do that, then let me know.
ND
Okay, make sure that the body is CLEAN before you paint. Make sure to scuff it up a bit with some scotchbrite pad/steel wool, to make it more abrasive. Also, make a lot of thin coats, instead of one big one. It also helps to heat the cans a bit in some warm water to make the paint spray morw evenly.
OK
The most important thing you can do to prevent paint from shipping is to make sure that you are using the correct paint. There are many different paints just make sure you get one that's designed to work with lexan.
