Best way to start
Got a new C6-R body and i was wondering what now Do i need to paint first ? then trim and reme the body post holes out ? or reme the mounting holes first to get the body centered so its easy to see where to mark the holes while the body is clear? Or can i trim the whole body then paint? The body does have the paint and peel protective film on the body so thats why i askek the last Q.
Thank you for any advice.
C3
C3
TX
It's much easier to cut first, then paint as long as the body is for you. If your selling the body, just paint and let the customer cut to fit their ride.
PA
Do all the trimming, make sure all the bumpers and everything are on so you know it will fit. I just dimple the body post holes and ream them after I am done painting. I have had paint seep under the protective coating and stick to the body, not a real big problem because it will wipe right off with a touch of alcohol, but why bother with the hassle.
