Metal flake
Metal flake
Is it possible to get a good metal flake look by applying a clear metal flake and then paint the desired color behind it? Has anyone done this? I am too cheap to buy an airbrush so it would be with spray cans
RE: Metal flake
There are several ways to paint metalflake. If you want say a red or blue color, spray the inside of the body candy red, then mix yourself some clear with silver metalflake, now when you look at the body in a normal way from the outside it will be red metalflake. Now if you want a multi colored body, jsut mask off what you want red, blue, green whatever colors you choose, then spray your silver flake. After you have finished with every color and the flake go over everything with silver paint. I've been doing this for years with no problems, however, I do use all urathanes as I own a auto body shop.
