Help please
Help please
Hi guys
Ive just finished painting a 350z bodyshell and when i masked the windows some of the spray crept inside (only a little )[:@][:@]
whats the best way to get it off i was gonna use a bit of white spirits washed with warm water,will it work or melt the lexan away???
thought it was worth asking before i put a hole in it lol
thanks
thanks
RE: Help please
well what works well in most cases is 1:1 of Lacquer Thinner and Alcohol
if your never sure of the Mix always a little more Alcohol than thinner...
and test on a small part to be totaly sure.....but we use this often and works wonders....
if using regular "PolyUreathane" then before it totaly cures you can use just Alcohol....
hope this can help....
RGX Racing
RGX Racing
