RC Painting, Detailing & Bodies Discuss painting techniques, methods and materials. Also detailing and bodies
Using Temporary Tattoos
Old 07-31-2007, 10:54 AM
jajbarton
Default Using Temporary Tattoos
Has anyone used temp tattoos?
Old 07-31-2007, 01:38 PM
jajbarton
Default RE: Using Temporary Tattoos
Or should I use Picture Glue like XXX Main has. There was an article in Sept's RC Driver.
Old 08-01-2007, 06:24 AM
Hezrou
Hezrou's Avatar
It might help if we knew what you wanted to do.
Old 08-01-2007, 06:57 AM
jajbarton
I'm wanting to do a College themed lid. Here are some of my choices.
http://dept.gatech.edu/adam/buzz/
http://www.sportsteamfanheaven.com/P...20Tattoos.html
I could also just use a vinyl decal on the outside.
Old 08-01-2007, 09:01 AM
Beasley1
Beasley1's Avatar
I recomend the vinyl decal. Ive never used a temp tatto even on my skin so I couldnt even tell you how they work. I have used decals and they seem to work good for me.
On the redbull I painted it white and everyhting else is decals on the outside. On the orange one I put the flames on the inside, painted it orange, then added more decals on the outside.
[img][/img]
Old 08-01-2007, 09:13 AM
Hezrou
Hezrou's Avatar
xxx main glue is good stuff. i have used it with printed images but you have to watch out for ink bleed in the image
Old 08-01-2007, 10:53 AM
bluecaka69
bluecaka69's Avatar
temp tatts work great also here some i did
Glue also works great heres some there of glueing
Old 08-01-2007, 07:23 PM
Nick2618
Nick2618's Avatar
you put the tatoons on the inside right and then just paint over them?
Old 08-01-2007, 07:43 PM
bluecaka69
bluecaka69's Avatar
yep thats what i did
Old 08-02-2007, 09:59 AM
jajbarton
B-69,
So how did you apply the tattoo to the lexan? Do you apply the side with the paper to the lexan or the side that goes against the skin to the lexan?
Old 08-02-2007, 04:18 PM
bluecaka69
bluecaka69's Avatar
the side that goes against the skin goes on the inside of body the only prob with temp tatts is that if the have writing on them the writing will be backwards but i put them on the inside of body so they dont scratch off when you crash apply them just as you would on your arm but on the inside of body
Old 08-15-2007, 08:49 PM
dolfan13
I tried using a temporary tattoo after seeing the pics on here. Unfortunately, it didn't turn out so good. Maybe you can tell me if I ddi something wrong. I applied the tattoo on the inside of the body (with the side that goes againste the skin against the inside of the body). The result was that you could see the tattoo perfectly on the inside of the body but it wasn't clear from the outside of the body. Do you have to use a special type of tattoo that is clear on both sides so that the image will be clear from the outside of the body?
Old 08-15-2007, 11:57 PM
Nick2618
Nick2618's Avatar
did you take the overspray mask off to see if it was clear? That might be causing the problem.
Old 08-16-2007, 11:44 AM
dolfan13
Yes overspray mask is off
Old 08-16-2007, 06:23 PM
bluecaka69
bluecaka69's Avatar
ORIGINAL: dolfan13
post a pic and le me see what you are talking about i kinda under stand but not fully
Old 08-17-2007, 05:57 PM
dolfan13
Here are a couple of pics......they didn't turn out too good but I think you can see what I am talking about. The dark parts should all be black but they aren't.
ID:	744013   Click image for larger version
Old 08-18-2007, 08:09 AM
tristan102
maybe the red is doing that?
Old 08-19-2007, 09:32 PM
dolfan13
No, it was actually alittle worse before I put any paint on it. The paint actually brought it out a little more.
Old 08-20-2007, 01:19 AM
bluecaka69
bluecaka69's Avatar
that looks like the tattoo was basked with ano0ther color the one i use dont have a color backing they are clear backed so the colors show through on the back also
Old 08-20-2007, 11:55 AM
dolfan13
Where do you get yours and what brand are they?
Old 08-20-2007, 01:42 PM
bluecaka69
bluecaka69's Avatar
actually I get them from a vening supply store or if you dont want a ton of them just go to a vending machine and buy some they are like 50 cents each
http://www.allstarvending.com/
http://www.gumballmachinefactory.com...TICKERSTATTOOS
