Dodge charger
Dodge charger
after much searching the only dodge charger body that i could find was an hpi one.
model hpi7184
the problem is, i drive a schumacher mi2, its a 200mm chassis. Past experience has taught me that, I suck at painting, modifying and even cutting body post holes
will this body fit the chassis? opinions?
model hpi7184
RE: Dodge charger
whats the size of the hpi body m8?
may have to drill yourself if its unpainted shell its easy,put body on chassis use a marker pen where mounts touch the top of shell
IF its a painted chassis little tip find a dark room,grab a torch,put body on chassis,beam torch light directly down on to body and you should see the mounts through the body,then mark with pen.
hope that helps im sure i read in rcca that the hpi were in 190 and 200mm
