HPI Body Question
HPI Body Question
Hello All,
Will HPI 1966 Shelby Mustang 200mm Fit on the Tamiya TA02 Chassis? The Wheelbase on the TA02 is 260mm. I just want to make sure before I make a purchase. Thank you all very much!
VS
VS
RE: HPI Body Question
did some research and hpi has that body on a HPI Nitro RS4 3 EVO+ RTR w/1966 Mustang GT Body and according to towers spec the wheelbase on this car is 256 mm so only 4mm diff im pretty sure you can make it work kust go to this link and compare your dimensions to this on http://www3.towerhobbies.com/cgi-bin...=LXRSJ0**&P=ML
Thank you for your help bluecaka, I was aware the difference while reserching for different body's wheelbase measurement. I was just wondering if anyone have actually done it with good result. I will give it a try.
Thank you
VS
Thank you
VS
AB, CANADA
All right, I have a Jato and I want to put a cooler body on it than just the everyday stadium truck body... I found an HPI body: it is a 200mm body for a touring car. My question is how much chopping do I need to do to get it onto the Jato, and is it 'do-able'?
