Help with tinting windows
Any tips and tricks would be appreciated. I have tried tinting with the Pactra spray tint.
Results were not good. A lot of blotching, running, uneven, large specks, etc
Has anyone tried the Testors Transparent Black Window Tint?
Thanks guys
Thanks guys
RE: Help with tinting windows
I use fatint faskolor paint. Turn the psi up to 40 and work it slowly. Small sweeping patterns over the window being done. Then repeat till its as dark as you want it to be. Practice on a cheap piece of plastic glass or just a piece of glass. After it dries on the glass a razor blade will knock it right off so you can reuse the glass over and over.
