RC Painting, Detailing & Bodies Discuss painting techniques, methods and materials. Also detailing and bodies
Need help about surface primers
Old 02-28-2008, 04:47 PM
Shompola
Default Need help about surface primers
Reading the Tamiya manual for a car with a polystyrene body, they recommend to use a surface primer as a base coat. I have never painted polystyrene bodies and my questions are
1) What benefits are there with a surface primer.
2) Which surface primer should I use? There are white, gray etc.
3) After I have sprayed the body with a color, and I want to paint details such as lights, should I first paint it with a surface primer? Or maybe flat white color?
Thanks in advance.
Old 02-29-2008, 08:55 AM
hrdcoreglf
Default RE: Need help about surface primers
Do you have a picture of the body? You can melt polystyrene with paint that has to much solvent in it. probably the reason for the primer.
Old 02-29-2008, 10:45 AM
Shompola
I actually do not have the car yet. It is a Tamiya Pajero Metal Top Wide or something like that. I am planning in advance
I am going to use Tamiya's own TS colors.
