Cutting body holes
Cutting body holes
Hi,
I need to enlarge a hole on my shell.
Whats the best way of doing it? What sort of drill bit should I use? Should the drill be fast or slow?
Dont want to mess up my newly painted body!
Cheers,
A
Cheers,
A
RE: Cutting body holes
It the rear body mount hole on a hyper ST pro body - I think I need to enlarge it from about 10mm to 15mm (ish)
[link=http://www.amainhobbies.com/product_info.php/cPath/1_89_139/products_id/2381]Get one of these.[/link] Just about any hobby shop should have them.
on the subject of body holes, what is the best way to align the body mount holes so that the wheel wells are positioned correctly with the chassis. Mine always seem to be slightly off so I get a lot of rub when I turn.
My Feedback: (18)
OK
Make sure you mark the holes correctly by placing the body over the car and aligning it perfectly before painting. Mark the holes with a sharpie on the outside and drill them after painting. Depending on if the body is made for your car or if its a uni. then some extra trimming might be required to keep them from rubbing.
ORIGINAL: brett65
