i got the runs!!!
i got the runs!!!
i have just painted my r32 gtr skyline an have got a couple of runs thru the paint.i hear brake cleaner or brake fluid works well as a paint stripper and or oven cleaner.is this true? the video on you tube looks a little inconclusive.any help much appreciated
RE: i got the runs!!!
If you want to ruin your body go ahead and try one of them. You would be better off just using the body. Spraying to much paint at one time will cause the paint to run. Next time spray thin coats and let it dry and then repeat the process until you get the way you like.
