RC Painting, Detailing & Bodies Discuss painting techniques, methods and materials. Also detailing and bodies
HELP! measuring bodies
Old 04-29-2010, 08:36 PM
6topham9
Default HELP! measuring bodies
Hey I could use some help with measuring a body to create holes in the proper spots for the body clips. Whats the best way? There are no pre- sunk starter holes on this body.
Any help is great! I am new to all this and want to do the most of it the right way the first time.
Old 04-30-2010, 09:28 AM
Lars from Norway
Lars from Norway's Avatar
Default RE: HELP! measuring bodies
If the body is unpainted you can put it where it is supposed to be on the bodyposts and make some marks with a permanent marker where the body meets the posts. And then you use a center punch before you drill the holes so the drillbit don't get away.
