color changing paint?
I have seen the spaz stix color changing paints but is there a special way you have to spray them or something? explain someone [&:]
RE: color changing paint?
i hsve had trouble with spaz paints flaking off id go to ur local auto zone or auto parts store and buy the dupli-color color change piant its like 25 bucks but u get enough to paint 5-6 bodies and it dosent flake cause it bends with the lexan unlike the spaz paints
to apply all u need to do is spray 5-6 coats of the color change paint then back it with the black that comes with the kit it also comes with a clear coat but thats not needed give me a min and ill find the link to my paint job uning paint ^ they also have sevral diffrent color change pattrens purple to green/ gold to magenta and sevral others edit here u go its the 6th post from the bottom http://www.rcuniverse.com/forum/m_38...tm.htm#3814427 |
Nothing special at all. You just spray it on.
Check out [link=http://www.alsacorp.com]Alsa Corp[/link] for some of the most amazing and expensive color changing paints ever made. The "exposures" line in crazy! |
thanks for telling me that disc but if you do put a clear coat on just to protect the bodies will it change how the colors change or anything?
i wouldent think so the dupli color paint is made for painting cars so it gives u the clear coat to protect the paint but with rc bodies u paint underneath so the black is proecting the paint u rverse the dir that come with the paint
it says to paint black base coat then spray color change coat then cllaer coat but with rc u paint color change then black and the clear body acts as claer coat |
