Lexan Glosscoat/decal sealer?
This may sound stupid, but does anyone know if someone makes a gloss coat or decal sealer for the outside of lexan bodies(to seal the stickers/decals once applied to the bodies so they don't peel)? Thanks in advance.
RE: Lexan Glosscoat/decal sealer?
if your applying decals to an unpainted body put them on the inside of the case.
can you not buy clear some sort of clear glue and paste a thin layer of that onto them? |
I'm applying the decals that come with the body(therefore designed for the outside of the body), and was just wondering if there was a product made to spray on the outside of the body. Something similar to what you would use on a plastic model kit(i.e. Testors Glosscote #1261). It's not that big of a deal, I was just trying to find out if I could add a layer on the outside of the body between the stickers and the scratching surface(grass, dirt, gravel, pavement, etc...). Thanks for the reply.
http://xxxmain.com/glue.shtml Has A Glue U Put On The Face Of A Picture And Stick On The Inside Of The Body And Then Just Paint Over Them.
My Hyper 7 Body Is In The Works Right Now With A Shrek2 theme Or A Van Helsing Theme |
