Storing fuselage on the spinner
All:
This may have been answered before but many of us do this due to space limitations. Is there any negative effect on the engine (4 stroke) by storing the fuselage vertically resting on the spinner? Could it for example damage the bearings? Or is it harmless? Thanks!
RE: Storing fuselage on the spinner
I don't know about bearings, probably not, but you need to consider 2 other things - storing a plane nose down - fuel can run into theengine and cardthe methanol slowly evaporates, leaving gunk oil behind.
But probably more important is that the silicone tubing and clunk weight in the tank is then folded back on itself (U shape) and could get a "pinch fold" or get stuck in that position, leading to engine cut outs when climbing. For that reason I store all my fuselages nose up against the wall. Just plug the exhaust with papertowel .
Bundu
Bundu
Ive stored my planes nose down for the best part of 10 years.
Very rarely will a clunk fall forwards. It can happen but a swift shake of the fuse with the nose up, , will ensure the clunk is back where it should be.
Just a caveat though, I fly with 2 stroke motors and rarely will the engines receive a storage period of more than 4 weeks.
ORIGINAL: Freddy
All:
All:
Not a good idea... the plane could get used to see the ground in front of him... and this is not nice while flying... HAHAHA
ORIGINAL: Bundubasher
But probably more important is that the silicone tubing and clunk weight in the tank is then folded back on itself (U shape) and could get a ''pinch fold'' or get stuck in that position, leading to engine cut outs when climbing. For that reason I store all my fuselages nose up against the wall. Just plug the exhaust with papertowel .
Bundu
Bundu
He who does not re-plumb his engine/tank each years is looking for problems !
ORIGINAL: guille2006
