Pattern Rules Proposals
What AMA rules proposals would you like to see passed this cycle?
My list would include:
1. Something to eliminate the weight disparaty between EP and GP
2. Eliminate the mandatory class points and advancement system
3. Eliminate judging take off and landing in all AMA classes.
#2 was changed to make it not mandatory in the last cycle. You are free to stay in your current class as long as you want.
I know someone who applied for a waiver last year as well, but only one. The waivers are granted by the AMA by someone who is probably not involved in and is not personally aware of the circumstances behinfd the request and is under no obligation to go out and seek input. I suspect, although noone comes to mind, that many drop out rather than go through the waiver process.
Why not change to:
A pilot's class is determined by the selection of a class in the first contest attended each calendar year. This base class for the year may be the same as the previous year,any higher class or one class below. For the rest of the year the pilot may not fly in any class below the selected base class. This applies to all classes- Sportsman through FAI.
John
I think we need to quit trying to dumb down pattern. Back in the 80's and 90's when pattern was huge (yes, there were less other things to do), most of us got into it because the cool airplanes, and the competition. The sequences were very challenging with the planes we flew, even "Novice." How many Advanced guys could actually do 3 loops now, or even 3 rolls which was a staple back then. Many keep thinking that by lowering the difficulty and eliminating rules we will attract more people, and I think the exact opposite is true. You aren't going to get your average sport flyer to want to fly pattern. It requires a certain mindset and desire. I think as we get older, and I'm certainly not old, but we come to realize our limitations and change our thought process on why we do it. We need to remember why we got into pattern in the first place. I keep hearing how you have to spend a fortune to be competitive and this is not the case. I have flown several Wind 110 planes and I could fly them and be competitive at most contests in Masters. Are there advantages to a 2m plane, sure or we wouldn't fly them, but you to say that a slightly smaller plane isn't competitive just isn't the case. I have never had an unlimited budget in pattern and have always had to be smart with what I have bought. I have never owned and most likely will never own and Oxai plane, but I have certainly won a lot of contests where there were Oxai planes being flown. No matter what rules you create, people will always find a way to exploit them and people will spend more for the latest and greatest toys. We complain about spending 100.00 on a prop and such, but will easily spend 300-400 dollars to go to a contest for a weekend. Pattern is never going to be cheap, but I don't think it has to be near as expensive as many would want. There have been viable options for low cost competitive airframes for years. The Black Magic series comes to mind, but you had to build them. Jeff Carder's new Lightning is another example. They were both light and more than competitive in any class. Unfortunately what many want is an Oxai quality plane for a fraction of the cost and be able to put cheap equipment in it, and expect it to fly as well as the more expensive stuff.
I think the biggest detriment now to contest attendance isn't the cost of the plane, but the cost of the gas and such to get there. Get gas back to $1.00 a gallon and I bet you'll see the numbers at events rise, regardless of the cost of the plane.
Arch
Joe,
Why not change to:
John
People make there choices. If a person is really serious about continuing in this sport, they will make the effort to go through the waiver process. It's not that big a deal. Maybe the waiver process needs to be better defined and people need to be made more aware of it as an option. I don't know who approves waivers but I would think they should be processed through the contest board for approval, not someone at AMA to approve. Maybe someone here on RCU who is on the contest board can clarify this. Scott?
Your idea for change is ripe for controversy which we don't need.
Joe,
Why not change to:
John
Arch
<xml><w:WordDocument><w:View>Normal</w:View><w:Zoom>0</w:Zoom><w:PunctuationKerning /><w:ValidateAgainstSchemas /><w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid><w:IgnoreMixedContent>false</w:IgnoreMixedContent><w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText><w:Compatibility><w:BreakWrappedTables /><w:SnapToGridInCell /><w:WrapTextWithPunct /><w:UseAsianBreakRules /><wontGrowAutofit /></w:Compatibility><w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel></w:WordDocument></xml><xml><w:LatentStyles DefLockedState="false" LatentStyleCount="156"></w:LatentStyles></xml><style> Style Definitions */table.MsoNormalTable{mso-style-name:"Table Normal";mso-tstyle-rowband-size:0;mso-tstyle-colband-size:0;mso-style-noshow:yes;mso-style-parent:"";mso-padding-alt:0in 5.4pt 0in 5.4pt;mso-para-margin:0in;mso-para-margin-bottom:.0001pt;mso-pagination:widow-orphan;font-size:10.0pt;font-family:"Times New Roman";mso-ansi-language:#0400;mso-fareast-language:#0400;mso-bidi-language:#0400;}</style>
Consideration will be given to requests for reclassification to a lower class for various reasons, such as disability or breaks from participation of several years. For a contestant to be reclassified to a lower class, the contestant must petition via email (or letter if email is not available) to the contestant's AMA District Contest Board (CB) representative explaining the reasons for the reclassification. The CB representative will forward a recommendation for approval/disapproval to the AMA District Vice President (DVP). The AMA DVP will concur/non-concur and forward the decision to the petitioner and AMA District CB representative with an info copy to the AMA Technical Director.
This suggests that either you become disabled or take a few years off. It does not appear to cover the reasons I suggested earlier except very indirectly("for various reasons"). As soon as there is a suggestion that you take a few years off before applying, I would consider that to be a very negative aspect of the rule. While I know that waiver requests have been accepted that do not appear to qualify, how many competitors have just quit after reading the rule? While is entirely possible that a waiver request has never been rejected, how would a potential waiver requestee ever know that?
I'm also missing the controversial aspects of the proposal I made.
John
I can see with your suggested paragraph that there will be someone who will jump back and forth. Maybe it needs to be stated that once you move down a class you must remain there a minimum number of years. Also, FAI is totally independent of AMA and should not be included. You can already jump back and forth from FAI to AMA. I know a certain FAI pilot who flys Advanced from time to time. That individual never flew Masters and has every right to fly Advanced when he feels like it.
I'll bet somebody has mentioned it somewhere before, but it appears winter is Pattern Silly Season.
Speaking of landing... I have flown Intermediate for a couple of years and started practicing Advanced this fall, which I intend to fly in the upcoming season.
I was at my small local field on December 30 enjoying the chance to fly my Osiris in the bizarrely good weather we've been having lately. Temps were close to 60 and the wind was nearly dead calm.
The field is a pretty small one that is located in a County Park - on top of a land fill, naturally - with hillsides sloping away from the small runway (23 feet x 300 feet) and the comparatively small amount of real estate surrounding it. At the bottom of one of the hillsides is the Hudson River, which you want to avoid at all costs. Because of the overall layout, it is a place where deadsticks don't often end well because the pilot cannot see the model below the crest of the hill. Even powered landings can be difficult if a bad approach is made that eats up a lot of the runway.
Although I learned how to fly there and have made literally thousands of flights (and landings!) at that location since then, I still find it helpful to practice landings and deadsticks, which I spent the good part of one of my flights doing with the Osiris. I practiced by pulling the throttle stick back when the plane was in situations where landing would be awkward or difficult and then doing a mock deadstick approach back to the field. It occurred to me to practice it because I know that sometimes batteries develop bad cells without us noticing it, or I forget to set the timer, or ignore it, whatever. And I am all too familiar with the insidious dangers of deadsticking there, or overshooting landings. When the LVC kicks in, usually there is only one shot at a good landing.
So thousands of flights later and with a few Pattern seasons behind me, I am still practicing landings and it amuses me to hear that this basic skill should be de-emphasized for new Pattern pilots.
All of this My Very Humble Opinion, of course.
<xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument></xml><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles></xml><style> Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}</style>
7. Pattern event classes: The outdoor Pattern event shall be divided into five(5) classes. The first four (4) classes shall (in order of increasingdifficulty) be referred to as Sportsman, Intermediate, Advanced and Masters.The fifth class shall be referred to as the FAI class. The Sportsman class issupplemental (see Supplemental and Provisional Rules of the General Section ofthe Competition Regulations). Competitorsmust be advised prior to the start of the contest of any planned deviationsfrom standard AMA rules pertaining to the events they have entered.
As to objecting to flyers jumping back and forth year to year, you give an example of someone doing that contest to contest under the current rules. I can't see this being a real issue in any case. So what if someone did bounce back and forth?
John
The VF3 is now open from firewall to turtleneck like a good electric should be and I am going to pick up paint tomorrow for the touch up. I NEVER want to try and get a plane back like that again.
I'll bring you some goodies to welcome Spring properly.
If that's the case, I deserve it, no matter who it is.
I never flew Advanced. I went from pre-turnaround Sportsman to Expert T/A. To think of it, I've been banging my head for years in Masters at the Nats and nothing to show for it. Never won a thing at a Nats. If this idea became a rule, I'd seriously consider moving down to Advanced just to have a chance at some Nats hardware which I otherwise probably will never get in Masters. My other option Fun Scale.
Matt, Yep thats who I was thinking about.
Why not fly Basic IMAC? The pattern planes would be legal in Basic. I am seriously considering it for this coming year
BTW- IMAC may have some screwed up ways of doing things but at least they got the Basic thing right....
Great. So you're telling me I'm gonna get my @$$ kicked by a guy flying a trainer.
When my grandson isn't flying his trainer and I feel like funning, I try to do that too....Very difficult by pattern standard
Do you need the redundant batteries?
$100.00 is chicken scratch compared to the $3500.00 or so that you doled out for your airplane.
Teo
Maybe I'm an odd-ball, but I like being judged on takeoff and landing. I think the whole flight should be done with precision.
As Joe L mentioned earlier, for a while take-offs and landings were not judged, but the consensus was to go back to judging them.
I might propose a rule change:
In order for someone to propose a rule change, he/she must have been flying Pattern for at least five years consecutively and must have competed in at least 3 contests per year and must fly Advanced or above.
This would prevent a lot of ill-conceived suggestions from those of us who don't have nearly enough experience nor historical perspective concerning Pattern to be proposing squat.
The only problem I have with scoring T/O and landings is if you're not flying off of a paved runway or a grass runway that is perfectly level like a putting green. The small bumps you can't see from the pilots station cause your plane to either jump in the air or bounce on landings.
Other than that, I think scoring the T/O and landings keep it safe . . .
An experience requirement for proposal submitters would sure cut down on discussions like this forum. OTOH, observations from a fresh perspective and / or "out of box" thinking has the potential for providing good and useful proposals. I suspect we're better off allowing proposals from all quarters and relying upon the experience of our contest board to sort it all out - these folks usually way exceed the experience requirement you suggest.
A proposal that might keep the older generation more interested and competitive would be some form of score handicapping. I favor 0.5% addition to the score for each year of age, say above 55. Could really be made interesting if 0.5% were deducted from scores of those below age 30.
