YS170DZ Quits on downwind leg after takeoff
I am recently breaking in a new YS170DZ engine and ran several tanks of Cool Power YS 20/20 fuel through it on the ground and use the APC 18.1x10W prop. On the ground the idle, mid range, and top end are perfect but as soon as I get airborne on the downwind leg the engine just quits while at a mid to mid/high throttle setting. The needle is open 2 turns. I was afraid to close it more as the engine is still new. Or should I just close it to 1.5 -1.75 turns?
I put the engine in a used Angel's Shadow which came with a long pipe see picture. Could it be that they only run well on the Hatori short pipe? Have you guys had experience with using the long pipe for the YS170DZ?
Thanks in advance for any ideas.
Do this, that, that and this and then solved..
Regards,
Don
P.,S., likely fuel issue. I have my needle at 2 1/4 to 2 1/2 turns out on my 170. Overheating check ventalation for exit air. Check valves working ok. Tank is getting vent and no suctioning, Do you run a fuel filter between the tank and the needle valve. Pull the needle valve out and push fuel though it just in case. When it quits does it knock hard or just quit smoothly. Take a video and post to youtube. Best, Don
Regards,
Don
We have one person that says 2 1/2 turn out on the HS and another that says 1 1/4 turns out. That is a VERY wide range for the same engine. There must be something amiss with one or both of those engines
I agree with Don's post "When it quits does it knock hard or just quit smoothly". This info will help diagnose the issue. In addition have you used a tach to adjust the high speed mixture? Peak the RPM with the tach and then just slightly rich. I'm fairly new to YS so I'll stick my foot in my mouth and say 300 RPM rich.
Ken
Ken
Ken
Ken
I had a cdi issue a few years back which drove me mad doing exactly what's described. You could tune it all day on the ground and it would quit on the downwind leg after takeoff, it turned out the sensor in the crankcase was intermittantly faulty in a strangely consistant type of way??
