Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
Reload this Page >
FANTASISTA EVO Build Thread by ISAAC NAJARY
Old 07-23-2015, 12:43 AM
  #76
najary
najary's Avatar
More
ID:	2110751   Click image for larger version
ID:	2110752   Click image for larger version
ID:	2110753   Click image for larger version
ID:	2110754   Click image for larger version
ID:	2110755   Click image for larger version
ID:	2110756   Click image for larger version
ID:	2110757   Click image for larger version
Old 07-25-2015, 12:23 AM
  #77
najary
najary's Avatar
More
ID:	2111047   Click image for larger version
ID:	2111048   Click image for larger version
ID:	2111049   Click image for larger version
ID:	2111050   Click image for larger version
Old 07-25-2015, 07:40 AM
  #78
n233w
Inspiring!
Old 07-26-2015, 09:39 PM
  #79
najary
najary's Avatar
Here I made the correction of what I did in post 69.
Because this is the first time that I am going to use the Futaba 9174 wing munt servo,
I did not took in considerations that this servo has a special flunch around it.
The mistake was that I should not cut the wing skin for the servo munt.
I should glue this servo munt exactly as I glue the other servo in the wing.
Sorry,
Isaac Najary
ID:	2111329   Click image for larger version
ID:	2111330   Click image for larger version
ID:	2111331   Click image for larger version
ID:	2111332   Click image for larger version
ID:	2111333   Click image for larger version
ID:	2111334   Click image for larger version
Old 07-27-2015, 08:33 AM
  #80
najary
najary's Avatar
Today I received the RS contra drive with 91 mm spinner and Hacker C54 motor.
http://www.ralphschweizer.com/startseite.htm
All parts are top quality.
Ralph Schweizer service and the technical support is superb,
Thank you Ralph.
ID:	2111379   Click image for larger version
ID:	2111380   Click image for larger version
ID:	2111381   Click image for larger version
ID:	2111382   Click image for larger version
ID:	2111383   Click image for larger version
ID:	2111384   Click image for larger version
ID:	2111385   Click image for larger version
ID:	2111387   Click image for larger version
Old 07-28-2015, 09:12 PM
  #81
najary
najary's Avatar
More
ID:	2111574   Click image for larger version
ID:	2111575   Click image for larger version
ID:	2111576   Click image for larger version
ID:	2111577   Click image for larger version
ID:	2111578   Click image for larger version
ID:	2111579   Click image for larger version
ID:	2111580   Click image for larger version
ID:	2111582   Click image for larger version
Old 07-28-2015, 09:13 PM
  #82
najary
najary's Avatar
More
ID:	2111584   Click image for larger version
ID:	2111585   Click image for larger version
ID:	2111586   Click image for larger version
Old 07-28-2015, 09:17 PM
  #83
najary
najary's Avatar
More
ID:	2111588   Click image for larger version
ID:	2111589   Click image for larger version
ID:	2111590   Click image for larger version
Old 07-28-2015, 09:18 PM
  #84
najary
najary's Avatar
More
ID:	2111592   Click image for larger version
ID:	2111593   Click image for larger version
Old 07-28-2015, 09:19 PM
  #85
najary
najary's Avatar
More
ID:	2111595   Click image for larger version
ID:	2111596   Click image for larger version
Old 07-31-2015, 05:16 AM
  #86
bandicootf16
Hi Isaac
Great thread. How is the build going. The RS CRS drive certainly looks impressive. Why did you choose this drive as opposed to the Brenner drive. There doesn't seem to be a lot of information out there on the RS drive. Do you know what reduction ratio it uses and maximum current draw.
David
Old 07-31-2015, 08:37 AM
  #87
najary
najary's Avatar
More
ID:	2112045   Click image for larger version
ID:	2112046   Click image for larger version
ID:	2112047   Click image for larger version
ID:	2112048   Click image for larger version
ID:	2112049   Click image for larger version
ID:	2112050   Click image for larger version
ID:	2112051   Click image for larger version
ID:	2112053   Click image for larger version
ID:	2112054   Click image for larger version
Old 07-31-2015, 08:39 AM
  #88
najary
najary's Avatar
More
ID:	2112056   Click image for larger version
ID:	2112057   Click image for larger version
ID:	2112058   Click image for larger version
Old 07-31-2015, 09:02 AM
  #89
najary
najary's Avatar
Originally Posted by Alex Voicu
Beautiful work Isaac!
Can you give us some details about the wing construction? I see some good opportunities here to save considerable weight for my future builds. I would be interested to know what is the thickness and weight of the wing balsa sheeting, material and thickness for the root rib, weights before covering?
Thanks.
Hi Alex,
Thank you for the compliments.
The thickness is 2 mm and weight of the wing balsa sheeting is 17-18 gram for 100X910 mm sheet.
The thickness is 2 mm and weight of the wing root ribs is 19-20 gram for 100X910 mm sheet.
The weights before covering are 265, 266 gram.
Best regards,
Isaac Najary
ID:	2112060   Click image for larger version
Old 07-31-2015, 09:21 AM
  #90
najary
najary's Avatar
Originally Posted by bandicootf16
Hi Isaac
David
Hi David,
I choose the RS CRS drive because I needed 91 mm spinner and the Brenner drive is only 82 mm spinner.
The RS CRS drive with the Hacker C54 is the littlest contra drive available, as far as I know.
If it is good for Mr. Wolfgang Matt, it is certainly good for me.
https://www.facebook.com/photo.php?f...type=1&theater
As for you other questions, you can ask Mr. Ralph Schweizer
[email protected]
Best Regards,
Isaac Najary
Old 07-31-2015, 09:50 AM
  #91
Alex Voicu
Originally Posted by najary
Hi Alex,
Best regards,
Isaac Najary
Thanks for your answer Isaac, very nice work. Your wings are very light, i must find some better balsa sheets in the future because the weight saving can be significant. The best sheets i could find here locally were around 23g.
In post #76, did you also add a doubler to the root rib? Most of the strength at the root rib probably comes from this doubler, is it made of liteply? Did you measure its weight? I think the root rib in my wing weights too much and i'm looking for a solution to reduce its weight in the future.
Old 08-01-2015, 05:28 AM
  #92
najary
najary's Avatar
Hi Alex,
Do you ask about this pic?
Old 08-01-2015, 12:25 PM
  #93
Alex Voicu
Hi Isaac,
Yes, that's the rib doubler i was talking about.
Old 08-02-2015, 08:41 AM
  #94
najary
najary's Avatar
Hi Alex,
Hi Alex,
This is not a doubler, this is a temporary 2mm balsa spacer between the root rib and the fuselage (it is glued to the root rib with a very few super glue drops).
In this plane, the root rib is curve because the fuselage is curve at that point.
I use this balsa spacer to attach the root rib to the fuselage with some pins when it glued to the wing (see pic).
The spacer also allows the carbon wing socket to pass into the root rib (this is a change I did, originally it does not pass into the root rib) (see pic).
After the root rib is glue to the wing, the temporary 2mm balsa spacer is remove (see pic).
In my opinion the root rib has very little to do with the wing strength, it is made of 1.5 mm plywood, it is very light (I did not measured it), and it mean function is to have a good place for the anti-rotation pins and for the screw that attach the wing to the fuselage.
Best regards,
Isaac Najary
ID:	2112431   Click image for larger version
ID:	2112432   Click image for larger version
Old 08-02-2015, 09:39 AM
  #95
Alex Voicu
Thanks for explaining it in detail Isaac, i understand now.
I used 3mm liteply for the root rib just to be safe, and judging from the pictures it looks like Dave Snow used the same material for his wing designs. My root rib is very long (580mm) so it's also quite heavy. It weighs around 30% of the whole internal structure of the wing, so i'm looking for something lighter. The Fantasista uses some interesting solutions so this may be very useful in the future.
Old 08-05-2015, 09:00 AM
  #96
najary
najary's Avatar
More
ID:	2112954   Click image for larger version
ID:	2112955   Click image for larger version
ID:	2112956   Click image for larger version
ID:	2112957   Click image for larger version
ID:	2112958   Click image for larger version
Old 08-10-2015, 05:19 AM
  #97
najary
najary's Avatar
More
ID:	2113657   Click image for larger version
ID:	2113658   Click image for larger version
ID:	2113659   Click image for larger version
ID:	2113660   Click image for larger version
ID:	2113661   Click image for larger version
ID:	2113662   Click image for larger version
ID:	2113663   Click image for larger version
ID:	2113665   Click image for larger version
Old 08-10-2015, 05:21 AM
  #98
najary
najary's Avatar
More
ID:	2113667   Click image for larger version
ID:	2113668   Click image for larger version
ID:	2113669   Click image for larger version
ID:	2113670   Click image for larger version
ID:	2113671   Click image for larger version
ID:	2113672   Click image for larger version
Old 08-15-2015, 12:41 AM
  #99
najary
najary's Avatar
More
ID:	2114456   Click image for larger version
ID:	2114457   Click image for larger version
ID:	2114458   Click image for larger version
ID:	2114459   Click image for larger version
ID:	2114460   Click image for larger version
Old 08-15-2015, 12:43 AM
  #100
najary
najary's Avatar
More
ID:	2114462   Click image for larger version
ID:	2114463   Click image for larger version
ID:	2114464   Click image for larger version
ID:	2114465   Click image for larger version
