YS DZ200cdi
#253
I have to remove a 3 blade for transport, so that's a problem.
Yes, a bigger ute would be good. Maybe a Silverado 2500 long bed
#254
As I won't have a direct comparison with the 2 engines, I ran my standard 200 on the test stand with the same prop.
I also ran the S again and a bit more tuning. It's now very close, maybe 1/8th turn rich on the reg still. The S reg is flush with the housing, whereas the standard 200 is the width of the bevel out.
The S has a slight increase in rpm, maybe 100 - 150 RPM or so and it throttles up quicker and a bit smoother. I also think the idle is a bit more steady.
With a few flights to fine tune it, I think it will be a fantastic engine. Saying that, I am more than happy with the standard 200.
#255
Hello Scott
Thank so much for your answer.
The price difference being low, it is better to buy a 200 s and have fun
Claude
My favorite plane in flight with 200DCDI
Hi Claude,
Claude
#257
A quick question on YS 185 CDI.
How do you know if the pump is on the way out?
Mine behaves normally but recently when I pull up for a manoeuvre it sounds like it is starving of fuel coughing and spluttering.......like a lean run.
The pump has 130 flights and it takes a lot of priming to get it started .
Any advice will be appreciated ...thanks in advance
#258
130 flights isn't much for the pump. If the pump is wearing, the reg will need to be richened.
How soon after landing are you starting it again?
#260
Is this the reason you fitted the new ignition module?
When exactly does it cough and splutter? Like, is it only when throttling up, going vertical, under load etc.
After the first run, shouldn't have to prime again. Do you clamp the fuel line to engine while on the ground?
#261
Hello
did you measure the pressure ?
claude
claude
#263
Hi Scott,
Thanks for your reply.
The engine will basically start and run good on the ground but it takes a lot more priming than normal .Idle on the ground is good .......up to a minute with good pick up.
The splattering occurs at the top of the manoeuvres ie at the top of a loop.........it sound a bit like BBBRRRR with loss of power and sometimes a lot of smoke .....once I throttle back it runs ok........straight and level flight is no problem either
regards
regards
#264
Hi Scott,
regards
regards
Run it at full throttle on the ground. You may get a slight rpm drop in the first few seconds, but that's normal. It should then hold that rpm. Keep it at full throttle for around 20 seconds.
#265
Hey Thanks mate I think it is starving of fuel as it loads up at the top of the manoeuvre hence the Juddering sound which leads me to believe the pump is on the way out.......
Just checked my notes on the engine and the engine has 160 flights ....time for a new pump !!!!
#267
Fitted a new pump last night ....the engine started with normal priming rocking the prop back and forwards about 10 times
Initially the engine was hesitating to accelerate and quit on advancing the throttle...........richen the pump 1/8 of a turn ....better but not enough so richen 1/8 of a turn and the engine was now responding so run the engine at close to full throttle for 20 seconds and check the idle again ....this time it appeared a little rich so lean the pump a little and the idle was now pretty good for 1.5 minutes with normal acceleration to full power.....only difference the vibration on the airframe was now noticeably higher than before......will need to investigate this one further.
Will fly when the wind settles down and will report further.
regards
regards
#268
regards
regards
It would have been good to try the original pump set richer though. You have richened the new one, which indicates the reg was lean.
Flying will tell the story 🙂
#269
Flew the Engine today in Moderate wind and the engine behaved normally with lots of power .....no problems at the top of the manoeuvres .
Scott I am glad i changed the pump because it did feel tight when removed from the engine.
regards
regards
#270
I had one sieze just after take off with of one of my Valiants. A swamp out front, no altitude and nowhere to go.
Glad you got it sorted 🙂 The 185cdi is the nicest and most user friendly engine I've had.
#271
Yeh its good when the diagnose is correct..........I think due to the Covid 19 the engine was grounded for 3 months with no fuel going through .....this may have caused a bit of corrosion inside the pump !!!!
My 185 CDI is 3 years old and I agree a lot more user friendly than the early 170 CDI.
I reckon for me the later version of the 175 CDI was the best.
#272
After flying, I empty the tank then run it until it stops. That's all.
#273
Hello
Good news
I have 175, 185 et 200 CDI.
I agree, my favorite engine is 175CDI with APC 20 x 10,5.
175 CDI is powerful, torquey, very smooth and more fuel efficient than the others.
claude
Good news
claude
#275
A quick question for the experts out there .....
Does the position of the prop in relation to TDC have any influence on the amount of vibration exerted on the airframe?
thanks in advance
thanks in advance
