Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
KARAT from RT DESIGN, Build Thread by ISAAC NAJARY >
Old 09-07-2021, 02:01 AM
najary's Avatar
Originally Posted by bandicootf16
Nice work Isaac
Does the Karat have have any wing stagger. Most designs seem to have some positive stagger but looking at the interplane strut arrangement on the Karat it may have no stagger or possibly negative stagger. While positive stagger may improve lift efficiency this doesn’t make sense with an aircraft that spends half it’s time inverted where positive then becomes negative stagger. I guess the best arrangement would be zero stagger. Maybe aerodynamically stagger doesn’t matter that much and then it just becomes a style issue, where a little positive stagger “looks nice” when the model is sitting on the ground and it looks right.
What do you mean by positive or negative stagger?
Old 09-07-2021, 02:07 AM
najary's Avatar
KARAT finish process - step 3
wattsup (10-10-2021)
Old 09-07-2021, 04:34 AM
Originally Posted by najary
KARAT finish process - step 2
Isaac, silly question. How do you clean the fuse after wet sanding with dish washer soup?
Thanks.
Old 09-07-2021, 01:27 PM
Hi Isaac
My understanding is that positive stagger has the top wing forward of the bottom and negative the top is behind the bottom. With no stagger the top and bottom wing LE would be inline/square to each other with reference to the fuselage datum.
Old 09-11-2021, 09:31 PM
najary's Avatar
Thanks.
Hi,
This is not a silly question, after wet sanding I clean with soft cloth and methanol.
Best regards,
Isaac Najary
Old 09-11-2021, 09:36 PM
  #31
najary's Avatar
Hi Isaac
Hi,
The KARAT has no stagger.
Best regards,
Isaac Najary
Old 09-12-2021, 04:10 AM
  #32
spl
Default composite construction material.
what material is used in the composite Rohacell, Divinycell, or something else ?
Old 09-14-2021, 12:24 AM
  #33
najary's Avatar
Sorry, I don't know.
Best regards,
Isaac najary
Old 09-14-2021, 12:32 AM
  #34
najary's Avatar
Preparing the stands for the clear coat
Old 09-22-2021, 05:10 AM
  #35
najary's Avatar
KARAT finish process - step 4
The following 3 users liked this post by najary:
ini (09-22-2021), Ricardo M. (09-22-2021), wattsup (09-22-2021)
Old 10-04-2021, 12:19 AM
  #36
najary's Avatar
KARAT finish process - step 5
wattsup (10-04-2021)
Old 10-13-2021, 08:39 AM
  #37
najary's Avatar
KARAT finish process - step 6
wattsup (10-13-2021)
Old 10-14-2021, 10:56 PM
  #38
najary's Avatar
KARAT finish process - step 7
Old 10-17-2021, 09:23 PM
  #39
najary's Avatar
KARAT finish process - step 8
wattsup (10-18-2021)
Old 10-20-2021, 02:02 AM
  #40
Beautiful work Isaac. After all the years of following your other builds, I have only 2 questions. What is the name or model number of this particular spray gun and the size needle you normally use to achieve these painting results? Thanks in advance.
Old 10-21-2021, 02:22 AM
  #41
najary's Avatar
Hi,
The nozzle size is 1mm
Best regards,
Isaac Najary
Old 10-21-2021, 02:35 AM
  #42
najary's Avatar
KARAT finish process - step 9 (last)
The total finish weight is 265 gram.
Old 10-23-2021, 09:56 PM
  #43
najary's Avatar
More
wattsup (10-24-2021)
Old 10-24-2021, 07:34 AM
  #44
najary's Avatar
More
Old 10-29-2021, 02:43 AM
  #45
Hello Isaac.
I am enjoying reading through all of your build threads and they are teaching me so much. I have a couple of questions:
1. what type / brand of paints do you use?
2. What is the purpose of the Patifix self-adhesive?
thanks, Bill
Old 10-29-2021, 09:03 AM
  #46
ini
That Patifix is thin felt layer on sticker. Reduces vibration and noice, also wear of contact surfaces.
Old 10-29-2021, 09:14 AM
  #47
I kinda thought that's what it might be. I've just never seen it pictured on any build threads before.
Old 10-31-2021, 10:27 PM
  #48
najary's Avatar
Originally Posted by GorillaToast
Hello Isaac.
thanks, Bill
The brand of paints is DUPONT.
Old 11-01-2021, 02:34 AM
  #49
Thank you.
Old 11-08-2021, 06:48 AM
  #50
najary's Avatar
More
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
