Hanno Prettner
Hanno Prettner
Hi all does anyone have a good idea for a plane to be powered with an OS 60 Hanno Prettner special. This engine has never been run since 1989 its my Dads engine but he has given it to me a presant. any thoughts would be great thank you.
FL
RE: Hanno Prettner
If that is the engine I believe it is, it is an O.S. Rear Exhaust .61. If that's it, then I suggest a Brushfire.
Tha Brushfire is a Steve Rojecki designed plane that flies about as true as they come. Brushfires are available from Carolina Custom Aircraft.
For Prices and information please email [email protected]. They will do their best to return all messages promptly.
Good Luck!
Gordon
Good Luck!
Gordon
RE: Hanno Prettner
Put it into an RC City Jeckyll (smaller 67" version.) This was the best combination I ever flew until an in-flight battery failure brought it to a sad end.
Eoin
Eoin
RE: Hanno Prettner
MK Skystar 90 would be a perfect match. I'm building mine with a Webra 80 rear exhaust and the entire engine and header fits inside the cowl.
The CA models Widebody 60 is also a good match, or the Modeltech Calypso if you can find one.
