Adjustable Stab
Adjustable Stab
The Finesse that I'm building has removable stab with adjusters. There are no wing adjusters. I understand about about adjusting the stab to eleminate elevator trim, but what if you are trying to compensate for aileron trim? Can you accomplish this with stab adjustment, more on one side? Is it common to have both stabilizer and wing adjusters? What are your thoughts on using stab adjusters? Thanks,
Steve
Steve
RE: Adjustable Stab
You will have maximum flexibility with adjusters on both wing and stab, but you also increase the installation and trimming complexity when you do that.
I prefer adjusters on the wing only. The stab is normally fixed in my planes for two reasons: these are smaller and easier to get perfect than wings and a fixed stab installation is much much lighter than adjustable stabs. You can also include that a fixed stab produces a far stronger tail group than adjustable will. There are no negatives in my view.
It does require that you get the stab in right to begin with, and that is the main assumption.
MattK
MattK
