European Championships
Old 09-13-2006, 02:05 AM
  #76
ram_z
ram_z's Avatar
Default RE: European Championships
Hi
The pilot that I remember was
Ola Fremming-Norwey ZNline OXALYS OS140RX
Kimmo Kaukoranta-Finland Abbra OS140RX
Vertrek Haijo-Netherlands Synergy OS160FX
Daniel Sayski-Israel Tornado-2 OS140FX
Old 09-13-2006, 02:49 AM
  #77
f3a05
Thank you---I'll pass the info on.
Old 09-13-2006, 03:19 AM
  #78
Kimmo Kaukoranta
Kimmo Kaukoranta's Avatar
Also my young team mate, Lassi Nurila was flying a two stroke. He had the OS140RX in his own design plane called "Nuristin". PÃ¥l Westerhaug from Norway was also using the OS140RX in a CA Models Genesis.
I must say that many of the models with the OS140, including mine, looked a bit underpowered/overweight. They were clearly slowing too much on top of some vertical maneuvres like the half clover. Ola's Oxalys was the exception, it was light enough for the OS. I think I need to loose some weight or get some more power under the hood...
Old 09-13-2006, 04:16 AM
  #79
macleote
macleote's Avatar
what's prop do you use ?
I personnaly use APX 17X13N actually and it run great in vertical(15% nitro-10% oil). next season i will try 18X10, a friend try it on is partner and OS 140Fi and he find it amazing.
Old 09-13-2006, 04:38 AM
  #80
Kimmo Kaukoranta
I'm running the APC 18x10 (standard, not PN) with 15% nitro, 15% oil. The 18x10 is much better than the 17x12 I used previously, better vertical and better braking. I think the main problem is the weight at around 4.8kg. I will do some lightening in the winter, lipo's for the receiver, lighter fuel tank, maybe a carbon pipe etc. It's not like the plane stops on those maneuvres, it just slows down much more than the YS160/170 powered planes.
Old 09-13-2006, 04:58 AM
  #81
macleote
macleote's Avatar
don't forget that they use between 25-30% nitro on YS!!!!
Old 09-13-2006, 09:23 AM
  #82
papaone
papaone's Avatar
Hello
Dear Macleote
If you want you could use 25 % nitro on your OS140 RX. I think you'll fly better.
Regards
To do pleasure to our friend lolo !
ID:	523381   Click image for larger version
Old 09-13-2006, 12:58 PM
  #83
f3a05
Strangely enough(on the OS160) I had the opposite problem---using an Engel carbon 18/11, the judges were complaining of too much vertical accelleration/speed, and downlines were too slow.
As someone else kindly pointed out , better throttle management should help, but I took the easier option of an APC 17/12, with less moaning from the judges as a result.
Old 09-13-2006, 01:21 PM
  #84
piotrekpepe
Me:
Piotr Swiderek - POLAND - ZN line OXALYS - OS 140 RX-FI
Old 09-14-2006, 02:29 AM
  #85
Kema
Was there any gas engines and how they managed compared to glow 2-stroke powered setups?
Old 09-14-2006, 08:48 AM
  #86
piotrekpepe
Yes, probably 1 GAS engine - SM 30 in Prestige:
Krzysztof Urbanski - POLAND - Wistmodel PRESTIGE - SM 30
More: http://www.f3a.com.pl/prestige.htm
About 200 photos from F3A European Championship 2006 on my site: http://www.swiderek-f3a.pl
Best regards
Piotr Swiderek
Old 09-14-2006, 11:48 AM
  #87
Kema
ORIGINAL: piotrekpepe
Best regards
Piotr Swiderek
Oh of course I have ordered some parts from him in past.
Old 09-14-2006, 04:45 PM
  #88
macleote
macleote's Avatar
Heyyy papaone!!! how are you dear friend!!!!! is our french naruke building a new awesome pattern plane during the winter season ????
Old 09-15-2006, 04:07 AM
  #89
papaone
papaone's Avatar
Hello Macleote
yeah I decide to do my own plane. Fuselage will be built in wood.
Regards
Old 09-15-2006, 04:19 AM
  #90
f3a05
Not so much Naruke as Rodin, or Bernini, or even Michaelangelo!
Old 09-15-2006, 05:41 AM
  #91
radray
radray's Avatar
How about the Mintor 170? It is such a nice looking engine, is anyone in Europe having success with this engine?
Old 09-15-2006, 06:12 AM
  #92
bla bla
Just about everyone bought one, then sold them on several flights later.
Old 09-15-2006, 07:11 AM
  #93
papaone
papaone's Avatar
Hello MPX 4000
Friends of mine (Julien and Olivier Quellier got 3 differents Mintor to test them).
They gave up theses engines. Very long and difficult to set up and engine stop in flight with no reason.
regards
Old 09-15-2006, 07:23 AM
  #94
radray
radray's Avatar
Thank you Bla Bla and Papaone!
Ray
Old 09-15-2006, 08:32 AM
  #95
Neo02
Neo02's Avatar
ORIGINAL: papaone
Living very close to the Mintor plant (about 100km from here), we visited them several times and also tried to help by giving suggestions on how to improve the engine's reliability, which was the main problem. Power was never an issue as the 140 (but also the 170) had plenty. Our friendly approach was eventually turned down without notice once a new team member and test pilot dropped in. Never heard from them since. It's a pity, because the engines are a beauty to look at and - for once - spare parts were truly around the corner from where we live.... and not in Japan!
We have also given up trying to make the engine work: those of us who tried reverted back to the truly problem-free OS 140 RX.
They are now in the business for multi-cylinder engines. Bad tongues say that if they are unable to make even one cylinder work, it will be very unlikely that they will succeed with the newer engines...
But now back to electric power, shall we?
Regards,
-Fabrizio
Old 09-15-2006, 04:17 PM
  #96
flywilly
My Feedback: (121)
Hey Papaone,
Great looking design. Any chance of getting a set of plans? (at your price of course) There are still a few of us that like to build (especially wood fuselages with 1-piece wings!!)
Regards,
Will Bartlett
Old 09-15-2006, 04:58 PM
  #97
papaone
papaone's Avatar
Hello Will
This is the Addiction by Starcraft
http://www.starcraft.co.jp/
Regards
Please send me your e-mail address. I 'll send you some informations.
As you, I like to build wood plane.
My own design plane named Legend. Fuse in wood with 1 piece wing made in foam and balsa.
ID:	524519   Click image for larger version
Old 09-16-2006, 11:46 AM
  #98
flywilly
My Feedback: (121)
Hey Papaone,
I sent you and email.
Your legend looks great - especially for a wood fuselage! I hope Mike Hester sees this (he designed the 'Black Magic'). I'd love to have plans for your Legend!
Thanks for the Starcraft website. Great looking pattern ships, but I don't think they sell 'basic' kits (just the unassembled parts), I wish they did!
Happy Flying,
Will
Old 09-16-2006, 11:55 AM
  #99
Adamg-RCU
Adamg-RCU's Avatar
That Legend is very good looking!
Old 09-16-2006, 01:14 PM
  #100
papaone
papaone's Avatar
Hello Will
Thanks you for your congratulation about plane Legend. I have the plan et send you if you want.
A friend of mine bought the kit of Addiction version 1 like you see on pictures . Dealer of Starcraft speaks english and is very nice guy.
He answers very quickly at the differents questions. Kit is complete and great quality.
Yes I like planes of mike Hester. Very good posts about building wood plane.
ID:	525036   Click image for larger version
ID:	525037   Click image for larger version
ID:	525038   Click image for larger version
ID:	525039   Click image for larger version
