Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
Reload this Page >
CAMODEL PASS-PORT BUILD (very slow)
Old 12-20-2008, 09:52 AM
  #51
bkennedy
bkennedy's Avatar
Default RE: CAMODEL PASS-PORT BUILD (very slow)
Very nice Job on the build thread Tuny, Passport looks Great !
Bryan
Old 12-22-2008, 01:44 PM
  #52
jim woodward
Tuny,
Any progress lately? I have settled on how to mix-out the roll coupling. I spent 6 flights yesteray determined the best way to mix it out. Because the plane flys with such little rudder movement (especially with T-cannalizer), you need to use a Point mix and set it at 3% flat to start. Then, between the neutral point, and about 40% of your rudder-stick movement, you want the mix to rise from "0" to 2% (move the rudder stick and you can see the corresponding mix point value). From 40% to the 100% of the stick movement, you can raise from 2% to 3 or 4%, whatever you end up with. The linear mixes just don't work well because again, due to the low amount of rudder movment, a 4% linear mix is almost undetectable.
Jim
Old 12-23-2008, 07:59 AM
  #53
tuny
Thanks Jim!
hopefully more progress today, lots of work here at the office..
TUNY
Old 12-24-2008, 07:32 PM
  #54
tuny
Finally!!!! more work done..
Rudder and rudder post.
the standard rudder post for the fuselage was to big and heavy so I decided to build a smaller one from 3/16 balsa and 1/16 balsa cross grained. so its very strong and light, I saved 10 grams.
- rimmed the end of the fuselage straight
- trimmed the rudder traling edge to its particular curve and added 3/16 balse trailing edge, i dont like to leave it with just foam and covering...
- new rudder post
- leading and trailing edges on rudder
- rudder post glued to fuselage with epoxy and microbaloons
- some sanding on the rudder and glued the rudder tip blocks.
some pictures...
MERRY CHRISTMAS TO EVERYBODY!
ID:	1096009   Click image for larger version
ID:	1096010   Click image for larger version
ID:	1096011   Click image for larger version
ID:	1096012   Click image for larger version
ID:	1096013   Click image for larger version
ID:	1096014   Click image for larger version
ID:	1096015   Click image for larger version
Old 12-25-2008, 10:38 PM
  #55
tuny
More work done.
finished the rudder post, sanded double beveled for extra rudder throw.
then installed hinges
instal the rudder in place and hold it tight with some masking tape so I can sand the rudder tips to shape using the fuselage as a guide.
marked rudder control horn location and rudder pull-pull cable exit holes in fuse using a long thread holding it from where the rudder servo should go.
installed rudder horn
installed tail wheel.
pictures...
ID:	1096631   Click image for larger version
ID:	1096632   Click image for larger version
ID:	1096633   Click image for larger version
ID:	1096634   Click image for larger version
ID:	1096635   Click image for larger version
ID:	1096636   Click image for larger version
ID:	1096637   Click image for larger version
ID:	1096639   Click image for larger version
ID:	1096640   Click image for larger version
ID:	1096641   Click image for larger version
Old 12-25-2008, 10:40 PM
  #56
tuny
more..
ID:	1096643   Click image for larger version
ID:	1096644   Click image for larger version
ID:	1096645   Click image for larger version
ID:	1096646   Click image for larger version
ID:	1096647   Click image for larger version
ID:	1096648   Click image for larger version
ID:	1096649   Click image for larger version
Old 12-27-2008, 11:56 PM
  #57
tuny
more.
Wheel pants.
I installed the wheels and wheel pants using a 8/32 screw as an axle, and a 2-56 screw with blind nut as an anti rotation screw, wheels are Du-bro lite wheels, in my opinion the ligthest on the market. they are mounted on 1/16 plywood, with balsa used to match the pant shape, everyting glued with CA and kicker, the wheel pants are made from polyester resin so epoxy will not hold there.
pictures...
ID:	1097868   Click image for larger version
ID:	1097869   Click image for larger version
ID:	1097870   Click image for larger version
ID:	1097871   Click image for larger version
ID:	1097872   Click image for larger version
ID:	1097873   Click image for larger version
ID:	1097874   Click image for larger version
ID:	1097876   Click image for larger version
ID:	1097877   Click image for larger version
ID:	1097878   Click image for larger version
Old 12-30-2008, 10:42 PM
  #58
tuny
more...
Engine instalation
first made room in the nose to fit the engine and opened the side cooling holes.
then the engine will be mounted on a YS super mount, to do this first I made a template of the mounting plate shape and made a 1/8 balsa dummy mounting plate
next make some ingeniering to make all that engine parts to fit in the nose and be aligned at the correct angle....(still working on that part..)
pictures so far...
ID:	1099943   Click image for larger version
ID:	1099944   Click image for larger version
ID:	1099945   Click image for larger version
ID:	1099946   Click image for larger version
ID:	1099947   Click image for larger version
ID:	1099948   Click image for larger version
ID:	1099949   Click image for larger version
Old 12-31-2008, 06:43 AM
  #59
Aresti-RCU
Tuny,
There are several pictures about a similar installation in this web page: http://www.deltafly.com.ar/gallery_inst/index.php
Click on the "Genesis", "Osmose", and "Passport YS170" options on the left side of the screen and you will see how CaModel does it. Mr. Stabile is the pro builder for CaModel in Argentina.
Old 01-01-2009, 07:40 PM
  #60
tuny
thanks aresti, good help.
engine instalation.
First sanded de spinner plate on the fuselage and glue 4 small pieces of 1/16 balsa to get spinner clearence
then installes the engine with spinner and worked with the plane vertical, this way I let gravity do the alingnin job for me, I let the spinner sit on the fuselage at its correct angand then installed my dummy mount to make a template with the fuse shape.
designed the engine mount using a structure made of 1/8 plywwod (where needed) and complete the shape with balsa to save weigth, and then laminated with carbon on both sides.
installed the blind nuts in place (four 3mm screws will hold the engine in place)
finally installed the engine and spinner again, aligned everything and glued with epoxy and microbaloons.
pictures.
ID:	1101122   Click image for larger version
ID:	1101123   Click image for larger version
ID:	1101124   Click image for larger version
ID:	1101125   Click image for larger version
ID:	1101126   Click image for larger version
ID:	1101127   Click image for larger version
ID:	1101128   Click image for larger version
ID:	1101130   Click image for larger version
ID:	1101131   Click image for larger version
ID:	1101132   Click image for larger version
Old 01-01-2009, 07:41 PM
  #61
tuny
more...
ID:	1101134   Click image for larger version
ID:	1101135   Click image for larger version
ID:	1101136   Click image for larger version
Old 01-01-2009, 10:11 PM
  #62
jim woodward
First class work Tuny!! VERY nice!
Jim
Old 01-03-2009, 01:20 PM
  #63
tuny
Thanks Jim! glad you like it, did you get your new kit yet?
Firewall: the supplied firewall was 1/4 balsa laminated with glass on both sides, really strong!, but using the YS mount is not necessary a strong firewall, so I made a new one with 1/8 balsa, sanded to reduce weigth an then laminated with carbon on both sides, it ended up really ligth about 16 grams less than the stock one.
then trimmed out the spiner plate on the fuse.
finally engine instaled, everything aligned as it should be!... great!
pics...
ID:	1102450   Click image for larger version
ID:	1102451   Click image for larger version
ID:	1102452   Click image for larger version
ID:	1102453   Click image for larger version
Old 01-03-2009, 01:21 PM
  #64
tuny
one more..
Old 01-03-2009, 11:55 PM
  #65
tuny
more...
muffler.
ID:	1102916   Click image for larger version
ID:	1102917   Click image for larger version
ID:	1102918   Click image for larger version
Old 01-04-2009, 12:41 AM
  #66
JoeBagOfDonuts
Nice work, tuny. Good choice of engine too! :-)
Old 01-04-2009, 01:41 PM
  #67
tuny
Thanks Joe!!!
throttle servo.
Futaba 3155 micro servo using a 2-56 rod with a nylon clevis on the engine and a Z-bend on the servo, mounted on a 1/8 lite ply mount.
pics.
ID:	1103312   Click image for larger version
ID:	1103313   Click image for larger version
ID:	1103314   Click image for larger version
ID:	1103315   Click image for larger version
ID:	1103316   Click image for larger version
ID:	1103317   Click image for larger version
Old 01-04-2009, 02:11 PM
  #68
Ryan Smith
My Feedback: (25)
Beautiful work, Tuny!
It makes me want a Pass-Port now!
Old 01-04-2009, 10:54 PM
  #69
tuny
Thanks Ryan!!!
more progress...
chin cowl,
first trimed the inside to make some room and to loose weigth, about 4 grams saved...
then opened the cooling holes, header clearence hole, pipe exit hole, glow plug hole
next installing hold screws....
pics..
ID:	1103750   Click image for larger version
ID:	1103751   Click image for larger version
ID:	1103752   Click image for larger version
ID:	1103753   Click image for larger version
ID:	1103754   Click image for larger version
ID:	1103755   Click image for larger version
ID:	1103756   Click image for larger version
ID:	1103758   Click image for larger version
Old 01-05-2009, 01:07 AM
  #70
RC_Pattern_Flyer
RC_Pattern_Flyer's Avatar
Thanks for the fine example on how to cut the hole for the exhaust, that is coming soon for me as well.
Chuck
Old 01-05-2009, 10:17 PM
  #71
tuny
Glad to help Chuck!!!
more work done..
-Needle valve opening, (needle valve extension is a sullivan flex cable with a wheel collar soldered in one end, and some fuel tubing to protect the fuse)
-cowling holding screws, two 4-40 screws will hold the cowl, atached up to down, acces thru the side cooling holes in the fuse, mounted on 1/8 lite ply reinforcements.
-Extra cooling exits, after doing some "math" I think some extra exit is needed to correct ventilation so I added two extra holes in the back at the end of the pipe tunel.
pictures.
ID:	1104463   Click image for larger version
ID:	1104464   Click image for larger version
ID:	1104465   Click image for larger version
ID:	1104466   Click image for larger version
ID:	1104467   Click image for larger version
ID:	1104468   Click image for larger version
ID:	1104469   Click image for larger version
ID:	1104471   Click image for larger version
ID:	1104472   Click image for larger version
ID:	1104473   Click image for larger version
Old 01-05-2009, 11:42 PM
  #72
toddblose
My Feedback: (10)
toddblose's Avatar
Tuny,
Great job, your work is perfection
Old 01-06-2009, 10:37 PM
  #73
tuny
Thanks Toddblose!!!!!!
more work...
fuel System:
-tettra shut off valve
-tettra outlets
-tettra check valve (not so good but i cant find a YS one, if anybody knows where can i get one please!)
-hangar 9 fuel dot for overflow line.
-fuel filter
I made 1/32 plywood reinforcements to mount the components to the fuse, this whay they dont get vibration loose or damage the fuse.
pictures..
ID:	1105251   Click image for larger version
ID:	1105252   Click image for larger version
ID:	1105253   Click image for larger version
ID:	1105254   Click image for larger version
ID:	1105255   Click image for larger version
ID:	1105256   Click image for larger version
ID:	1105257   Click image for larger version
ID:	1105259   Click image for larger version
ID:	1105260   Click image for larger version
Old 01-07-2009, 10:02 PM
  #74
tuny
More...
Ailerons.
I waited until the end to cut the ailerons because I like to make all the aligment with the wings in one piece, so now I did the same as on the stabs..
Old 01-07-2009, 10:04 PM
  #75
tuny
forgot the pics.....
ID:	1106010   Click image for larger version
ID:	1106011   Click image for larger version
ID:	1106012   Click image for larger version
ID:	1106013   Click image for larger version
ID:	1106014   Click image for larger version
